99 SLK crank, no start sometimes..HELP! - Mercedes-Benz Forum
post #1 of 34 (permalink) Old 08-03-2009, 08:21 AM Thread Starter
Date registered: Aug 2009
This car is driving me nuts, I have a 99 SLK 230. The car will crank, but not start sometimes. Put the key in the ignition and it will keep spinning even with my fingers off the key, I have to manually bring the key back to stop it. Replaced ignition switch and it seem to take care of the problem for about a week, then it did the same thing. Sometimes it will crank and run, but will quit, sometimes start, sometimes not. You can let it sit and it will start and sometimes not. What is the surround that goes around the tumbler(it has a wire on it and goes behind the instrument cluster)..if you pull it off, the car will spin and quit..when you put it back on the car will continue to spin..if you wiggle it sometimes the car will start..maybe just coincidence. Any help would be appreciated.
chromeitcycles is offline
post #2 of 34 (permalink) Old 08-03-2009, 10:16 AM
DJC013's Avatar
Date registered: Mar 2009
Vehicle: 2001 SLK 320 Auto in Linarite Blue
Hello, recently had the exact same problem on my 2001 SLK320. It turned out to be the Crankshaft Position Sensor (Fault Code P0335). I bought one from a MB dealer, but have since learned that there are possibly available from Bosch service centre`s, car has been perfect ever since !!
Regards Damian.
2001 SLK 320 in Linarite Blue / Black Leather Interior 16 " Wheels
DJC013 is offline
post #3 of 34 (permalink) Old 08-03-2009, 10:37 AM Thread Starter
After trying to start several times throughout the day, it finally started and runs fine.Restarted it several times...just letting it run now. I know when I shut it off and let it sit it WILL do this again...think it still could be the sensor? and where is it located..thanks
post #4 of 34 (permalink) Old 08-03-2009, 12:20 PM
Chris A's Avatar
Date registered: Jun 2006
The CPS acts up mostly when it is hot but a few can do this when cold. They are located where the motor connects to the transmision. On top of the bell housing.
Women can fake orgasms. . . . men can fake whole relationships.
Chris A is offline
post #5 of 34 (permalink) Old 08-03-2009, 03:23 PM Thread Starter
I started the car several times today, and with no problems it started everytime. Let the car sit for a couple hours and it started again with no problems. A little while ago I cranked it up, it ran for a couple minutes and quit..now it will not start again. Where is the fuel pump relay located, I am wondering if this could be the problem...I was going to shoot some starting fluid in the injector and see if it will run...
post #6 of 34 (permalink) Old 08-03-2009, 03:32 PM Thread Starter
OK, shot starting fluid in the injector. Cranked up and ran till fluid was gone. Will not start now.
post #7 of 34 (permalink) Old 08-03-2009, 04:48 PM
Chris A's Avatar
You have a 99.. Have you read up on the K40 relay. It is a bank of relays that control your fuel and other things. It is located in the black box next to the battery. This thread has some pictures of what to look for when you get it open. https://www.benzworld.org/forums/r170...ssociated.html It takes less then 5 minutes to pull out once you find it.
Chris A is offline
post #8 of 34 (permalink) Old 08-04-2009, 09:57 AM
Chris A's Avatar
Were you able to check the K40.
Chris A is offline
post #9 of 34 (permalink) Old 08-04-2009, 10:21 AM Thread Starter
I will check it this afternoon when I get home..and it is a 98 model..my mistake..but it should still have the same module..I will post my findings. Thanks
post #10 of 34 (permalink) Old 08-04-2009, 04:00 PM Thread Starter
Tried to start car when I got home, would only crank-no start. So I disconnected the neg. and removed the K40 module. Pulled it apart and found NO melted or unsoldered terminals..put it back in. Tried to crank it several times and finally it started and ran for about 2 mins and it shut off. Restarted, but only would run for a few seconds and quit. Now it is back to NOT starting. Any suggestions, fuel pump relay, weak fuel pump, crankshaft sensor?
S320 sometimes won't start, but will always crank over. 1996s320 W140 S-Class 12 09-08-2009 10:03 AM
crank crank no start.. Riverad W163 M-Class 10 05-18-2009 02:22 PM
won't start, not crank sensor, help!! goclk500 C209/A209 CLK-Class 7 10-10-2008 04:00 PM
HELP no start/crank mmm etr C208/A208 CLK-Class 7 02-01-2008 07:23 PM
wont start on first crank rotormotor W124 E,CE,D,TD Class 9 05-18-2005 03:10 PM
