Electrical question(Possible wiring diagram needed) - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-07-2009, 01:48 PM Thread Starter
Date registered: Jun 2008
Vehicle: 98 SLK 230
Hey,
I'm building a turbo timer into my car, mainly due to the fact I have an A/F ratio display then. But I need to tie it into the ignition key cylinder. Does anyone have a wiring diagram for the key cylinder? Or can anyone tell me what each cable is? I know red is connection 30. But I need to find the Ign1 and Ign2 wires. Thanks in advance.
twitch_de is offline
post #2 of 5 (permalink) Old 06-07-2009, 02:28 PM
32krazy!'s Avatar
Date registered: Oct 2008
Vehicle: PROUD OWNER! 2002 slk32 AMG
try this. look at section 8i. this is mechaniccly the same as a slk32
http://www.majormotorshotrods.com/_d...ice_Manual.pdf
32krazy! is offline
post #3 of 5 (permalink) Old 06-10-2009, 12:27 PM Thread Starter
Vehicle: 98 SLK 230
I wish that was the answer I was looking for, but unfortunately its not. Cable colors dont match. Hoping anyone knows.
post #4 of 5 (permalink) Old 06-11-2009, 07:14 PM
DickB's Avatar
Date registered: Dec 2002
Vehicle: 1999 SLK 230
Connect to these it the fuse box. Open the cover and remove the top of the fuse box to expose a row of studs. The studs with the pink wires are ign 1 and 2. Use a voltmeter to identify. Crimp ring terminals on wires and attach to the studs.
DickB is offline
post #5 of 5 (permalink) Old 06-12-2009, 10:51 AM Thread Starter
Vehicle: 98 SLK 230
Fuse box in on the left side of the door. Or the fuse box in the motor room?
Electrical Diagram help needed JNLeChevet R/C107 SL/SLC Class 4 01-13-2009 05:28 AM
Electrical wiring diagram Perostbo W163 M-Class 0 05-22-2007 04:04 AM
Electrical wiring diagram (more) Les K (UK) R170 SLK-Class 5 11-27-2006 01:07 PM
Electrical Wiring Diagram- Airconditioning circuit premos W124 E,CE,D,TD Class 0 02-20-2006 12:47 AM
Electrical (or at least Radio) Wiring Diagram yawstring R170 SLK-Class 1 07-03-2003 01:22 AM
