MAF, AMS , AFM etc - Mercedes-Benz Forum
post #1 of 59 (permalink) Old 01-19-2006, 02:15 AM Thread Starter
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
MAF, AMS , AFM etc
MAF Mass Air Flow,
AMS Air Mass Sensor
AFM Air flow meter
Are all terms used in naming the Air sensor in the intake tube.
These can make many a defect in our vehicles from a slight drop in power to a major change bringing in the limp home mode[:0]
I have been researching many web sites on the MB MAF and have concluded the following.
All the Bosch inserts appear to have the same part number. F 00C 2G2 025
Inserts made by either Bosch or Pierburg.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=8030452466&sspa gename=STRK%3AMEWA%3AIT
http://www.x-desk.net/ximages/21302_pgsi0079en.pdf
The Pierburg PDF ref above is quite handy and also mentions problems with oiled filters.[:I]
I would like others to open the sensor from their MAF using a security torx to see if the part number is the same and you post results here.
There may be 2 Bosch part numbers so checking will help all.
The insert is a fraction of the whole assembly price .
Pix below were from a 1998 SLK 230 and an W202 2000
Bazzle
By
Bazzle is offline
post #2 of 59 (permalink) Old 01-19-2006, 10:03 AM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
RE: MAF, AMS , AFM etc
Wow, Impressive research. I will open my old one.
Kirill
Kirill is offline
post #3 of 59 (permalink) Old 01-19-2006, 11:58 AM
Date registered: Jun 2004
Vehicle: 1999 SLK-230 Sport
Mine, from a 1999 SLK 230, has a Bosch number F 00C 2G2 001 on it, I just replaced it a month ago after 36000 miles.
nijmegenguy is offline
post #4 of 59 (permalink) Old 01-20-2006, 02:17 PM
Miked619's Avatar
Vehicle: SLK in brilli silver
Send a message via AIM to Miked619 Send a message via MSN to Miked619
I dropped the guy an email, he does state it works for a 99slk, so this could be a cheap alternative!
Miked619 is offline
post #5 of 59 (permalink) Old 01-20-2006, 11:16 PM Thread Starter
Bazzle's Avatar
Might have to get one to carry as a spare?
Bazzle
By
Bazzle is offline
post #6 of 59 (permalink) Old 01-21-2006, 04:26 PM
16falcon's Avatar
Date registered: Oct 2004
Vehicle: 2002 SLK 32 AMG
Bazzle - 1/21/2006 1:16 AM
Bazzle
I was thinking the same thing. My car has about 36K miles and I don't think the MAF sensor has ever been changed.
16falcon is offline
post #7 of 59 (permalink) Old 01-22-2006, 11:52 AM
Miked619's Avatar
I ordered one from they guy, will let you know how it turns out. Hopefully it solves my misfire problems.
Miked619 is offline
post #8 of 59 (permalink) Old 01-22-2006, 08:25 PM
Kirill's Avatar
16falcon - 1/21/2006 7:26 PM
My MAF lasted about 38-40K
Kirill
Kirill is offline
post #9 of 59 (permalink) Old 01-23-2006, 07:20 PM
Date registered: May 2005
Vehicle: 1998 230 SLK
Just opened up my recently dead MAF from my 98. Original equip with Appox 24,000 miles. I tried to clean it which got me to and from work but that was about it. Replaced it and wow![:0]Hard to read ellement numbers but looks like... Bosch F 00C 2G2 001 Made in germany 816 / 769 02 1 A Replacement was bought online, Bosch 0 280 217 114 so I assume the guts are the same. I can pull if needed. Great research, hope this helps. [:D]
Keep on motoring,
Skookill
Skookill is offline
post #10 of 59 (permalink) Old 01-30-2006, 09:24 AM
ATYSLK320's Avatar
Date registered: Feb 2005
Vehicle: 2001 SLK 320
Hello Guys,
First of all, thanks for all the useful information that you've been sharing in this forum. Are the MAF sensors for the 230 & 320 the same? My car had a CEL and code P0173 (vent leaks or faulty MAF sensor) showed up when I had Advance Auto Parts in my area pull the code. How do you check vent leaks?
Thanks,
Al
ATYSLK320 is offline
