ABS Cement-Quick Fix Combined with Fiberglass for Broken Plastic and ABS Parts - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-12-2019, 06:52 PM Thread Starter
carltwo's Avatar
Date registered: Apr 2007
Vehicle: 1992 500SL, 1988 560SL, 1977 450SL, 1999 E320 4matic
Quoted: 83 Post(s)
Perhaps this is old news for some of you here. My friend's 1991 500SL had a damage trunk battery cover that was broken in more than 25 places, in which I think it appeared someone ran over it. I decided to make an attempt to repair it. In the past I used other method so I decided to try something new. The piece was originally made from ABS. I bought a can of ABS cement for $5.87 a Home Depot. I had a sheet of fiberglass laying around. Briefly sanded the area with 80 grid sandpaper, clean the area with "Prep-All", applied the ABS cement with the brush that came with the can, then applied the fiberglass and the ABS cement again, one coat, immediately followed by a second coat. The glue drys in and around 15 minutes. Then I moved on to the next crack. I had some pieces missing, but no problem as I easily reshape them using the same procedure as before. This procedure can be used for many other broken plastic parts in our cars, large or small. The photos attached show the results and how easy and quickly this can be done. Using a orbital sander with 220 grit the next day, allowing the cement to completely cured, I quickly smoothed out the raised areas, (no photos yet of the finished product). The ABS cement dries to a hard finish and melts in with the original ABS plastic part. It may look like a mess from the photos, but in the end it looks new again. It's now a hard and a rigid piece, just as it was before....
ID:	2534086   Click image for larger version
Name:	ABS ~1JPG.JPG
ID:	2534088   Click image for larger version
ID:	2534090   Click image for larger version
ID:	2534092   Click image for larger version
macysum, duh_vinci and Swany like this.
carltwo is offline
post #2 of 4 (permalink) Old 08-12-2019, 08:25 PM
mahunt's Avatar
Date registered: Feb 2008
Vehicle: 1997 SL600 Brilliant Silver Sport with grey/dark metal interior, 234K miles
Quoted: 397 Post(s)
What's the fuzzy side look like?
mahunt is offline
post #3 of 4 (permalink) Old 08-13-2019, 10:07 AM Thread Starter
carltwo's Avatar
Quoted: 83 Post(s)
That's the side insulation in which I pulled back to fix cracks and then re-glued the insulation back as there were no cracks on the bottom of the panel. If you mean the carpet side, here's a pic.
Name:	Carpet side of battery cover panel.jpg
RedLiner and duh_vinci like this.
carltwo is offline
post #4 of 4 (permalink) Old 08-13-2019, 06:01 PM
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
Thanks for sharing, certainly a great alternative to 2 parts epoxy - ready on the go!
Regards,
D
duh_vinci is online now
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
rp930
