Erratic climate control - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 08-09-2019, 12:48 PM Thread Starter
Date registered: Oct 2018
Vehicle: 1997 SL320
Quoted: 2 Post(s)
The climate control on my '97 SL320 has recently started to malfunction. Most of the time I have to turn off the auto function by decreasing the fan speed until the auto light goes out, then increase the fan speed to return it to the auto function. Sometimes the fan will come back on but mostly it won't. I can hear the AC compressor turn on when the auto function light comes on. It blows cold air when the fan works.
Any suggestions are appreciated.
Charles
Hogndogz is offline
post #2 of 8 (permalink) Old 08-09-2019, 03:19 PM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1997 SL500- 40th Anniversary
Quoted: 514 Post(s)
Charles
I could easily be mistaken, but it sure sounds like a fubar blower control regulator... Well documented in this forum, with complete pics and how-to. Search for GADHA Blower replacement for a starter...
Also see: https://www.benzworld.org/forums/r12...otor-heat.html
Best Regards...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #3 of 8 (permalink) Old 08-11-2019, 03:01 AM Thread Starter
Vehicle: 1997 SL320
Quoted: 2 Post(s)
Thanks Ears!
Hogndogz is offline
post #4 of 8 (permalink) Old 08-11-2019, 05:50 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
Quoted: 602 Post(s)
In most cases problems of this kind are a consequence of a faulty blower speed regulator. But the in-dash controller can be the problem as well, and since that possibility is quickly and easily checked, that is a logical place to begin. You can search my username and the words "blower" and/or "regulator" for details.
bobterry99 is offline
post #5 of 8 (permalink) Old 08-11-2019, 11:43 AM Thread Starter
Vehicle: 1997 SL320
Quoted: 2 Post(s)
Thanks BobTerry99. Good to know.
Hogndogz is offline
post #6 of 8 (permalink) Old 08-13-2019, 03:31 PM
kinglaw1's Avatar
Date registered: Nov 2016
Vehicle: 1991 500 SL R129
Hi,
I am a novice on this site and believe you have a video on the blower regulator problem. i have a 1991 500SL and have gone through 3 aftermarket regulators (129 821 33 51) two of which are MTC. The first one (cheap from China) actually worked for 2 days and then reverted to the high setting and cannot turn off. The next two when plugged in had a high whine similar to a radio frequency.
Have you seen this before? I saw your point about testing the control unit on the dash; what exactly is tested there (I have some mechanical skills)?
Thank you for any help on this topic
kinglaw1
kinglaw1 is offline
post #7 of 8 (permalink) Old 08-13-2019, 05:39 PM
Quoted: 602 Post(s)
Originally Posted by kinglaw1 View Post
I saw your point about testing the control unit on the dash; what exactly is tested there...
You are checking the voltage signal sent from the in-dash unit to the blower motor regulator. It should vary commensurate with blower speed setting. See this post: https://www.benzworld.org/forums/r12...ml#post3639421.
post #8 of 8 (permalink) Old 08-13-2019, 05:45 PM
kinglaw1's Avatar
Thank you so much; I will do that.
BPK
kinglaw1 is offline
