97 SL320 R129 Radio Code and P0410 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old Today, 03:56 PM Thread Starter
Date registered: Aug 2018
Vehicle: 2003 500sl; 2006 E350
Quoted: 2 Post(s)
Exclamation 97 SL320 R129 Radio Code and P0410
I got a radio from a donor car. I called the MB dealership with that car VIN number but the code is incorrect. Do I have any other way to know the correct radio code???
Also the check engine light just come on with a code P0410. I know is the secondary air pump failure. Where should I start prior purchasing a new secondary air pump. I will check the fuse first. Should I check anything else prior replacing the pump??
Thanks
maxi1211 is offline
post #2 of 5 (permalink) Old Today, 04:10 PM
ChipThome's Avatar
Date registered: Apr 2019
Vehicle: 1995 and 1996 SL320 One Keeper One For Sale
Quoted: 43 Post(s)
If it's a Becker radio, they sell a radio code service on Ebay for $20.
ChipThome is online now
post #3 of 5 (permalink) Old Today, 04:34 PM
FATHERTIME's Avatar
Date registered: Aug 2015
Vehicle: 94 SL320 98 SL500 99 SL600
Quoted: 231 Post(s)
Thanks
Start by checking for vacuum leaks and test the EVAP valve Gas cap can do that too.
John;
FATHERTIME is offline
post #4 of 5 (permalink) Old Today, 04:54 PM Thread Starter
Quoted: 2 Post(s)
Thank you. Going to buy on e-bay the code
maxi1211 is offline
post #5 of 5 (permalink) Old Today, 08:21 PM
AroundTheBenz's Avatar
Date registered: Oct 2015
Vehicle: 2001 SL500
Quoted: 130 Post(s)
I found this seller on ebay. No personal experience with the seller, but he has 100% positive feedback, and for a grand sum of $1.80 I think it's worth a try.
Hope this helps,
Peter.
AroundTheBenz is online now
