Oxygen sensors - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 07-03-2019, 08:31 AM Thread Starter
Date registered: Feb 2017
Vehicle: 1997 SL600
Quoted: 6 Post(s)
Oxygen sensors
I have a 1997 SL 600 V12, I had the motor replaced at 60,000 miles since then the check engine light comes on. The reading on the scanner is always the same P0135,P0155,P0130,P0150,P0141,P0136,P0161,P0156 that is the oxygen sensor heaters and circuits. I have had all the oxygen sensors 4 times with OEM sensors, replaced the cats, replaced exhaust from cats back and now all the dealer has to say “ I would bet you have to replace a lot of oxygen sensors “.
All that is left is the computer? Has anyone seen or no of someone that has had a similar problem and how it was fixed?
jensenr is offline
post #2 of 13 (permalink) Old 07-03-2019, 11:29 AM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 743 Post(s)
I assume your replacement motor is from the same model-year, and the Dealers knew that too so those new oxygen sensors are the correct ones and works with the old computer in the car.
Did the Dealers say anything about the computer ?
RKH is offline
post #3 of 13 (permalink) Old 07-03-2019, 12:06 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 576 Post(s)
I wonder if by chance something didn't get plugged in or plugged in correctly, or some wiring damaged during the engine replacement process. Or that the engine computer for the new engine is not compatible with 1997 MY.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #4 of 13 (permalink) Old 07-03-2019, 01:20 PM
ChipThome's Avatar
Date registered: Apr 2019
Vehicle: 1995 and 1996 SL320 One Keeper One For Sale
Quoted: 44 Post(s)
If prior to having the engine replaced you didn't have this problem and since the engine switch you do have the problem, the cause of your problem is back at that engine swap. If I were to take a wild assed guess at what is causing the problem I would say you got an engine from a different model year and not every computer connected component was swapped over from your old engine, giving you a hodge podge mess.
ChipThome is offline
post #5 of 13 (permalink) Old 07-03-2019, 05:31 PM
FATHERTIME's Avatar
Date registered: Aug 2015
Vehicle: 94 SL320 98 SL500 99 SL600
Quoted: 235 Post(s)
Too bad after all that you still have issues, how and who did the swap? I would imagine if all the components were transferred from the original engine you would have few issues. It's not an easy swap there are a lot of connectors involved and damage to the harness would be possible
John;
FATHERTIME is offline
post #6 of 13 (permalink) Old 07-03-2019, 07:47 PM Thread Starter
Vehicle: 1997 SL600
Quoted: 6 Post(s)
Yes it was the same year.
I have had it in 3 times trying to figure out why the oxygen sensors failed,the wiring were checked all were good. I asked about the cats, muffler and resonator and was told they shouldn’t have anything to do with it, I decided to replace those to eliminate them and now don’t know how to do
jensenr is offline
post #7 of 13 (permalink) Old 07-03-2019, 08:14 PM
RKH
RKH's Avatar
Quoted: 743 Post(s)
Hate to be throwing parts at it, but like yo said "the computer is what's left".
If you can borrow one that would be great but there are not many old V12 around.
RKH is offline
post #8 of 13 (permalink) Old 07-03-2019, 08:56 PM Thread Starter
Vehicle: 1997 SL600
Quoted: 6 Post(s)
I have had it back and they said that when the check engine light is off all the oxygen sensors parameters are with in specs.
jensenr is offline
post #9 of 13 (permalink) Old 07-03-2019, 09:00 PM Thread Starter
Vehicle: 1997 SL600
Quoted: 6 Post(s)
Mercedes installed all the original parts from old motor
There is only one anyone knows of I will call and find out if he would allow me to swap for a while
jensenr is offline
post #10 of 13 (permalink) Old 07-03-2019, 09:41 PM
Date registered: Jan 2019
car diagnostic tools OBD2 is in this link
Hi sir, what is model of Scanner tool?. I think you have to read the instruction of the manual of scanner tool. You can find some ways to solve the problems.
harveyspecter1209 is offline
