R129 Bose Stereo Question - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 06-25-2019, 03:46 PM Thread Starter
Date registered: Aug 2018
Vehicle: 1999 SL500
Location: Williamsburg, Virginia, United States of America
Quoted: 64 Post(s)
Hey guys,
I'm putting in a pioneer aftermarket stereo in my 99 SL500 with the bose package.
I used an adapter on the front and rear speaker connections but am unsure how to connect the subwoofer
There's a separate connector for it with three wires running to it. The wires aren't labeled and I'm wondering if anyone knows a good solution to the problem. I'm trying to figure out at least which is the I'm assuming ground? wire of the three so I can find the left and right channels.
Thanks
sully1218 is offline
post #2 of 14 (permalink) Old 06-25-2019, 04:00 PM
bartsitarski's Avatar
Date registered: Jan 2014
Vehicle: 1998 SL500 Sport
Quoted: 77 Post(s)
Originally Posted by sully1218 View Post
Hey guys,
Thanks
I got a harness from Crutchfield when I ordered my deck. It was literally plug and play after matching the wires. It had RCA jacks as part of the harness that plugged into the back of the deck and the sub works fine.
bartsitarski is online now
post #3 of 14 (permalink) Old 06-25-2019, 04:43 PM Thread Starter
Vehicle: 1999 SL500
Quoted: 64 Post(s)
Hey did you use the sub outputs in the reciever? I got a harness from crutchfield too and it only had the four outputs
Hey guys,
Thanks
post #4 of 14 (permalink) Old 06-25-2019, 11:25 PM
Vehicle: M113 SL500
Quoted: 156 Post(s)
You don't use the low level RCA subwoofer outputs from your pioneer stereo to send a signal to the bose subwoofer. The bose amp uses the high level speaker output signal from your headunit and amplifies the low frequencies to the subwoofer.
What you're talking about with a separate connector with three wires running to it, I have no idea. Pics?
brauhaus is offline
post #5 of 14 (permalink) Old 06-26-2019, 05:31 AM Thread Starter
Vehicle: 1999 SL500
Quoted: 64 Post(s)
I would but I sort of cut them off. I believe they are the cd changers wires and maybe automatic antenna. Just to be clelar though you used the front and rear outputs on the stereo? I appreciate it,
Thanks
post #6 of 14 (permalink) Old 06-26-2019, 11:04 AM
Vehicle: M113 SL500
Quoted: 156 Post(s)
Actually, come to think of it, for the R129 (sorry, I have more than 1 Merc with this generation of Bose), I think the bose system only uses the front speaker outputs as a signal to the bose amp, and the bose amp processes the signal and distributes it throughout the cabin's speakers. That's why at least in my 1999 SL, there was no front to rear fading with the stock headunit.
In short, you wire the speaker level wires to the harness. You don't use the subwoofer RCA outputs. You won't have independent subwoofer control with your Pioneer headunit, just like you didn't with your stock headunit.
Check the pinouts of your stock wiring harness. Are there rear speaker outputs that correspond to the pinouts for rear speakers on your adapter harness?
brauhaus is offline
post #7 of 14 (permalink) Old 06-26-2019, 11:08 AM Thread Starter
Vehicle: 1999 SL500
Quoted: 64 Post(s)
Okay I have the 80-PRS so I have the 6 preouts if that makes a difference. The wiring harness that crutchfield sent had 4 connectors so I used them for the front and rear. The unit isnt being as loud as it should so I was confused whether I actually needed all four or just the front.
post #8 of 14 (permalink) Old 06-26-2019, 11:48 AM
Vehicle: M113 SL500
Quoted: 156 Post(s)
The harness you were sent by cruthfield, do they have RCA connections or speaker wire connections?
As a kinda/sorta aside, I also have an 80prs in my R129. The gain structure on this headunit is such that you have to turn the volume up a lot more than you think you should. Not saying this is the problem you're having now, but it could be contributing.
Is your 80prs switched out of network mode?
brauhaus is offline
post #9 of 14 (permalink) Old 06-26-2019, 11:57 AM Thread Starter
Vehicle: 1999 SL500
Quoted: 64 Post(s)
I left it in the mode it started in, which according to the manual is standard. The harness has the adapter for that big plug that went into the old reciever. It has wires for the ground and 12v connections as well as 2 RCA (4 plugs) connectors. I plugged in the four for the front and rear in the preouts. I dont think the rear speakers are doing anything thats whats weird. I like it pretty loud but I need like 58 of 62 volume to be happy at normal road speed
Thanks
post #10 of 14 (permalink) Old 06-26-2019, 12:28 PM
Vehicle: M113 SL500
Quoted: 156 Post(s)
Ok, this has been discussed on this forum before. You ought to do a search, but you'll get more volume if you use the harness that has speaker wire connections instead of RCA, or you can cut off the rca connectors and wire in your speaker wires. The bose amp needs more signal volts than the preamp signal provides. 5v preouts on the 80prs sounds like a lot compared to other headunits with 2-4v, but this is 5v max, and speaker level voltage is much higher.
If you're going to remove the headunit to do so, just make sure that network switch is set to standard. Before you do that, you can also check if your output levels are maxed out on the 80prs. Go to audio settings and Front HPF2 and turn up levels to 0.
If you're going to bother with an 80prs, I'd suggest ditching the bose amp and speakers and going with the setup where you can start using all the features the 80prs has. The way you want to set it up now wouldn't be any better than if you bought one of Pioneer's ~$100 units, except for maybe time alignment and # of EQ bands.
brauhaus is offline
