ABS ESP Steering Angle Sensor - no luck - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-25-2019, 08:08 AM Thread Starter
Date registered: Jun 2015
Vehicle: '96 Mercedes S320, '99 Mercedes SL500
Quoted: 15 Post(s)
Hi all,
At the dealer and I had them replace the steering angle sensor for my ongoing ABS ESP problem. I bought the car with these lights on, and with a pull to the right.
The car still throws a steering angle sensor error after it was replaced.
Here is some helpful info:
The car came with a pull to the right. I got it aligned in Jan, but dealer said control arm bushings were worn and they couldnít perform a completely accurate alignment. Car still pulls right.
Could this alignment issue be the underlying cause? Or could it be worse: maybe the P/O curbed the car and bent something crucial.
P/O had the problem diagnosed at this dealer a year ago, and dealer gave an estimate, after diagnosis, to replace steering angle sensor. Now I finally get the work done and itís still faulty.
Does anyone have any experience with this? Going to leave the car with the dealer, but if anyone has any experience so I know what to expect/suggest, that would be appreciated.
Thanks.
Merc96 is offline
post #2 of 3 (permalink) Old 06-26-2019, 06:35 AM Thread Starter
Quoted: 15 Post(s)
Nevermind. It's all fixed! They had to reseat the new sensor a couple of times. It works like a charm, even though the car pulls to the right.
Merc96 is offline
post #3 of 3 (permalink) Old 06-26-2019, 08:55 PM
mahunt's Avatar
Date registered: Feb 2008
Vehicle: 1997 SL600 Brilliant Silver Sport with grey/dark metal interior, 234K miles
Quoted: 379 Post(s)
Now all you have to do is replace all the worn out parts of the front suspension and you'll be all set.
Merc96 likes this.
mahunt is offline
