Center Console Vacuum Lock Inoperative ('91 SL) - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-24-2019, 08:52 PM Thread Starter
Date registered: Mar 2014
Vehicle: 1991 500SL; 2014 GLK250 BlueTEC
Quoted: 14 Post(s)
In my '91 500SL, all of the interior compartments (sunglass storage, tape/cassette storage, door pockets, rear storage bins) vacuum lock correctly when I use the key to turn the lock by the center vents. The only compartment that doesn't lock is the center console. I've had the center console out, disconnected the black vacuum hose from it, and could not feel any vacuum pressure at the hose's yellow connector while turning the vacuum lock on and off.
My question is, where does this black rubber vacuum hose lead to, as I'm thinking that either the tube is cracked somewhere along the way, or the other end isn't connected?
Any info. or experience in dealing with this problem would be greatly appreciated. Thanks.
Pathung is offline
post #2 of 7 (permalink) Old 06-25-2019, 07:19 AM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1997 SL500- 40th Anniversary
Quoted: 500 Post(s)
Does it lock when the car is locked from outside?
Best Regards...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #3 of 7 (permalink) Old 06-25-2019, 07:27 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
Quoted: 566 Post(s)
Originally Posted by Pathung View Post
My question is, where does this black rubber vacuum hose lead to...
I presume it leads directly to the vacuum distributor located atop the transmission tunnel behind the console. For a look you would remove the wooden covering over the storage compartments and the carpet covering the floor of the compartments.
bobterry99 is offline
post #4 of 7 (permalink) Old 06-25-2019, 07:44 AM Thread Starter
Quoted: 14 Post(s)
I've never tried this - this assumes that the center console is on the same vacuum circuit as the door/trunk locks?
"wooden covering over the storage compartments and the carpet covering the floor of the compartments" - are these the two compartments behind the seats, or the "shelf"? The two covers may be made of wood, but are covered with carpet. The passenger side compartment has a plastic bottom covering that can be removed by undoing three plastic nuts, under which are a number of electrical control units - is this different from your car? Mine's a '91.
Pathung is offline
post #5 of 7 (permalink) Old 06-25-2019, 07:53 AM
Quoted: 566 Post(s)
...this assumes that the center console is on the same vacuum circuit as the door/trunk locks?
They are on separate pneumatic circuits, as there is one for the vehicle interior which can operate independently of the one for the exterior.
Yours is identical to mine. You actually can leave that plastic cover in place, probably, but it may be easier if you remove it.
post #6 of 7 (permalink) Old 06-25-2019, 09:15 AM Thread Starter
Quoted: 14 Post(s)
I've found it, more easily accessible from inside the driver's side storage compartment, rather than the passenger side (no hard plastic cover, just soft black carpeting that can be lifted). I'll dig into it when I'm home later.
Is there another vacuum distributor anywhere else in the car? Fumbling with the rear storage console and replacing the its lid-opening gas strut a few days ago, I noticed that the vacuum hose actually snaked forward, after exiting the console unit, along with the two wires (alarm and console light); all three seemed pinched under the car's carpeting/floorboard, and I wonder if this seeming pinch is preventing air from passing through the vacuum hose (though this seems like the factory setup, and I'm sure that the locking worked when the car was new).
Pathung is offline
post #7 of 7 (permalink) Old 06-25-2019, 01:35 PM
Quoted: 566 Post(s)
There is one located in the vicinity of the various electronic modules in the engine compartment, but it has nothing at all to do with locking.
I'd have another look at the pinched line.
