1999 500 SL Soft top issues (hydraulic fluid) - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-17-2019, 12:28 AM Thread Starter
Date registered: Jun 2019
Hello all:
I was raising the soft top of the 99 500 SL,
it started up just fine, then reversed and returned back inside
it's compartment. When I got out of the vehicle, I noticed hydraulic fluid
on the ground in front of the drivers side rear tire.
Never owned a 500 SL before and not sure what this symptom indicates or
where to begin.
Thanks in advance for your suggestions.
All the best,
Joe
jfhughes13 is offline
post #2 of 5 (permalink) Old 06-17-2019, 12:43 AM
Date registered: Sep 2013
Vehicle: 1992 500SL, 1993 300SE, 1997 S320L, 2000 C230K, 2003 E500, 2005 Smart ForFour, 2008 Smart ForTwo
Quoted: 78 Post(s)
Please use the search feature on the forum. The is a massive thread regarding these issues. Your seal will be leaking from a lifting ram and most likely need to send all hydraulics for a overhaul
BenzWillMakeHerDance is offline
post #3 of 5 (permalink) Old 06-17-2019, 04:29 AM
Date registered: Mar 2007
Vehicle: 2000 SL320, 2001 CLK320
Quoted: 368 Post(s)
It happens to every owner of a SL R129 some time or the other. Seals in the hydraulic cylinders wear out.
Search this forum.
Might add that it happens eventually to every Mercedes with a hydraulic operated hard top or soft top.
rorypff is offline
post #4 of 5 (permalink) Old 06-17-2019, 05:01 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
Quoted: 566 Post(s)
Originally Posted by jfhughes13 View Post
...I noticed hydraulic fluid on the ground in front of the drivers side rear tire.
Refer to this diagram from the TopHydraulics website to see the location of your vehicle's 11 hydraulic cylinders: https://www.tophydraulics.com/conten...benz-r129-info. You'll see that the left-side roof drive (main) and bow extension cylinders may be leaking.
If a cylinder is leaking you will see evidence of hydraulic oil at the point where the rod of the cylinder leaves the body of the cylinder.
At a minimum I would remove and rebuild the leaking cylinder and the cylinder like it from the other side of the car. For peace of mind you may wish to rebuild all of them at the risk of unnecessarily rebuilding a cylinder which has been serviced in recent years.
jfhughes13 likes this.
bobterry99 is offline
post #5 of 5 (permalink) Old 06-17-2019, 07:48 AM Thread Starter
yes I did and it was extremely confusing and often times argumentative with a bunch of dweebs talking trash...
but thanks for you instructions toward the obvious...
