1997 sl500 remote sync - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-16-2019, 06:29 PM Thread Starter
rt1
Date registered: Feb 2009
Hi any help would be great. My battery died so I put a new borsch battery in the car and then my remote stopped working. So I put in 2 cr2025 batteries in the remote. When I hit the button I see the infrared but it does control the car functions. So I tried to sync it to the car but was unsuccessful. Does anyone know the step by step instructions to sync? It sounds like there are 3-4 methods
rt1 is offline
post #2 of 7 (permalink) Old 06-16-2019, 06:56 PM
Benica's Avatar
Date registered: Sep 2010
Vehicle: 2002 Black SL500, 2000 Azure blue SL500, 2005 Silver (A209) CLK500
Quoted: 195 Post(s)
What I did is....put the key into the ignition and turn the car on for a few seconds. Turn off. Then try you buttons on your remote.
We are here on earth to do good unto others.
What the others are here for, I have no idea.
Benica is online now
post #3 of 7 (permalink) Old 06-16-2019, 06:58 PM
Benica's Avatar
Quoted: 195 Post(s)
I also replaced my battery in the trunk and the remote batteries....remote did not work until I started the car.
post #4 of 7 (permalink) Old 06-17-2019, 09:36 AM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1997 SL500- 40th Anniversary
Quoted: 500 Post(s)
I too, would like to know the MB procedure for a ‘97 as my OM states “...aim at the antenna...”
Best Regards...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #5 of 7 (permalink) Old 06-18-2019, 04:45 PM
FATHERTIME's Avatar
Date registered: Aug 2015
Vehicle: 94 SL320 98 SL500 99 SL600
Quoted: 234 Post(s)
Originally Posted by Ears View Post
I too, would like to know the MB procedure for a 97 as my OM states ...aim at the antenna...
My 94 says aim at the mirror.
John;
FATHERTIME is offline
post #6 of 7 (permalink) Old 06-18-2019, 04:51 PM
Ears's Avatar
Quoted: 500 Post(s)
Earlier versions had the IR sensor hanging down like a wart on the bottom of the mirror. Not so on a ‘97. There are sensors on each door handle and boot.
Best Regards...
RM Smith
Ears is offline
post #7 of 7 (permalink) Old 06-18-2019, 06:29 PM
Ears's Avatar
Quoted: 500 Post(s)
My bad... I typed "antenna", instead of "mirror". the reason this is confusing is as I pointed out above: no IR sensor on the mirror.
From my OM:
Synchronizing System:
The system may have to be resynchronized,
if the transmitter is
without voltage for several minutes.
To synchronize system, aim transmitter
eye (2) at inside rear view mirror
receiver and briefly press transmit
button (1) twice. Within approx. 30
seconds, insert key in steering lock and
turn it to position 2.
The infrared remote control should
once again be operational.
Best Regards...
RM Smith
Ears is offline
