722.6 trans solenoids - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-26-2019, 11:32 AM Thread Starter
FATHERTIME's Avatar
Date registered: Aug 2015
Vehicle: 94 SL320 98 SL500 99 SL600
Quoted: 230 Post(s)
I read an article a while back about a "blue" solenoid for the 722.6 trans has anyone installed these and what if any gain did you have.
John;
FATHERTIME is online now
post #2 of 6 (permalink) Old 05-26-2019, 12:59 PM
Administrator
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 825 Post(s)
I'm sure our transmission expert Martin (Mava) will comment
No trees were harmed creating this message, however some electrons were very inconvenienced.
RedLiner is offline
post #3 of 6 (permalink) Old 05-26-2019, 10:13 PM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1225 Post(s)
You may get great results or bad results:
https://www.benzworld.org/forums/w21...harshness.html
Martin
MAVA is offline
post #4 of 6 (permalink) Old 05-27-2019, 06:14 AM Thread Starter
FATHERTIME's Avatar
Quoted: 230 Post(s)
Martin
When I down shift into second gear in my 98 SL500 it takes too long to engage so I was hoping this would help that. My 94 SL320 and 99 SL600 do better. I know my 94 has a different gear box and it will get second when I need it. The 99 Sl600 will get it in half the time as the 500. The problem is too much free wheeling into the corners and have to use too much brake . This can be a little scary on new roads.
John;
post #5 of 6 (permalink) Old 05-28-2019, 10:45 PM
MAVA's Avatar
If the other gears are doing well, I doubt these solenoids will do you justice...
A) I assume filter and fluid are under two years old, and at proper level..
B) Your Transmission Computer(TCM) is dry, and not dripping with fluid.
C) Have you reset you TCM too? Like post 1:
https://www.benzworld.org/forums/w21...omp-reset.html
What Have you found out?
Martin
MAVA is offline
post #6 of 6 (permalink) Old 05-29-2019, 07:42 PM Thread Starter
FATHERTIME's Avatar
Quoted: 230 Post(s)
https://www.youtube.com/watch?v=kgcf31D8pcE&t=16s
Martin
Other gears work fine. New conductor plate and socket 15k ago. Cleaned out ATF on passenger floor board, seems like magic how it can get there. Opened TCM and dry no fluid there. I'm gonna try the reset.
John;
