92 SL500 runs rough after washing - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 05-25-2019, 06:03 AM Thread Starter
Date registered: May 2019
After either going to the car wash or washing with the hose at home the car will run very rough with major hesitation for a couple of days, I assume until it drys out. Doesn't look like any water is making it to the engine as even when I washed it with a hose and was very careful not to spray too much water anywhere it still does it. Car has 110,000 km on it and was imported 8 years ago from Japan to Canada
Any ideas?
Keith Kohlruss is offline
post #2 of 13 (permalink) Old 05-25-2019, 06:26 AM
Vehicle: 1999 E430; 2005 ML500
Quoted: 96 Post(s)
Most likely culprit is the ignition, with condensation getting into some insulating area. To isolate, I would take a spray bottle and spray around the plugs, plug wires and ignition module. If it causes the hiccup, you can isolate better by just spraying particular areas.
Hirnbeiss is offline
post #3 of 13 (permalink) Old 05-25-2019, 02:21 PM
Date registered: Sep 2013
Vehicle: 1992 500SL, 1993 300SE, 1997 S320L, 2000 C230K, 2003 E500, 2005 Smart ForFour, 2008 Smart ForTwo
Quoted: 72 Post(s)
Your post is confusing. I assume you are not washing the engine bay with the hose?
BenzWillMakeHerDance is online now
post #4 of 13 (permalink) Old 05-25-2019, 04:06 PM
Administrator
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 817 Post(s)
If he is then that can seriously affect the very sensitive electronics e.g. sensors etc.
A gentle hose is one thing but power washing the engine bay is sure to cause major damage
No trees were harmed creating this message, however some electrons were very inconvenienced.
RedLiner is offline
post #5 of 13 (permalink) Old 05-25-2019, 05:24 PM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 728 Post(s)
I recall Albert (aam) had some advice how to keep moisture out of the distributor
aam likes this.
RKH is offline
post #6 of 13 (permalink) Old 05-25-2019, 06:22 PM
Quoted: 72 Post(s)
Iíd never wash my engine with a hose, the risk is far too high for my liking. Letís hope that isnít the case
post #7 of 13 (permalink) Old 05-25-2019, 06:33 PM
Date registered: Apr 2019
Vehicle: 1995 and 1996 SL320 One Keeper One For Sale
Quoted: 31 Post(s)
Have you freshened up the ignition since you got it? You know, cap, rotor, wires, plugs etc ??? If not it's probably due for it and then see how your car wash experiences go afterwards.
ChipThome is offline
post #8 of 13 (permalink) Old 05-25-2019, 07:05 PM
aam
Greek God of the R129
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
Quoted: 230 Post(s)
Hahaha,
You have amazing memory!
The distributor/ contraception post....
I think that in this case water hits the EZL.
By the space between the hood and fender.
(Left fender side.)
Look if you have over the EZL a plastic protection cover/panel.
After washing check if that area is wet.
And, Or,
Check the condition of the rubber seal on the double fire wall. Water may hit the fuses, etc.
Regards,
aam.
aam is offline
post #9 of 13 (permalink) Old 05-26-2019, 03:59 AM
robm.UK's Avatar
Date registered: Jun 2009
Vehicle: R129 500 SL 1991
Quoted: 270 Post(s)
Originally Posted by aam View Post
Hahaha,
We all remember your French tickler Albert! I read that post, guessing itís the same one, maybe around 10 years ago.
aam likes this.
robm.UK is offline
post #10 of 13 (permalink) Old 05-28-2019, 08:59 AM Thread Starter
This happens when washing the outside of the car, not the engine. Thanks for some of the tips, I will follow up on them
