ADS pump leak - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-23-2019, 11:14 AM Thread Starter
Date registered: Apr 2019
Vehicle: 95 SL600
Quoted: 8 Post(s)
ADS pump leak
hey guys,
Ive been having this ADS leak since I got the car. Finally had a chance to track it down, and its leaking from where the lines bolt up to the pump. Is there a replacement gasket or o ring that is available? I tried finding something but Im not even 100% what to call it when i search.
I attached some pics as well, with a red arrow showing where the leak is.
Sam
ID:	2515086   Click image for larger version
Sam Alfano is offline
post #2 of 7 (permalink) Old 05-23-2019, 12:03 PM
mahunt's Avatar
Date registered: Feb 2008
Vehicle: 1997 SL600 Brilliant Silver Sport with grey/dark metal interior, 234K miles
Quoted: 379 Post(s)
Isn't that the engine oil cooler port?
If it is, then it takes 2 O-rings from the dealership.
FATHERTIME likes this.
mahunt is offline
post #3 of 7 (permalink) Old 05-23-2019, 12:22 PM Thread Starter
Vehicle: 95 SL600
Quoted: 8 Post(s)
Honestly, I dont know. Ill have to investigate it further I suppose.
I do know for a fact its leaking from the area I showed, just need to figure out how to fix it.
post #4 of 7 (permalink) Old 05-23-2019, 02:22 PM
FATHERTIME's Avatar
Date registered: Aug 2015
Vehicle: 94 SL320 98 SL500 99 SL600
Quoted: 235 Post(s)
Engine oil, just need O-Rings
John;
FATHERTIME is online now
post #5 of 7 (permalink) Old 05-24-2019, 04:48 AM Thread Starter
Vehicle: 95 SL600
Quoted: 8 Post(s)
you happen to have a part number?
post #6 of 7 (permalink) Old 05-24-2019, 05:54 AM
mahunt's Avatar
Quoted: 379 Post(s)
I just replaced mine this year, but I can't remember the part number.
I'm pretty sure your nearest MB dealership will be able to help. Don't expect them to be on the shelf.
Easy repair with just one Allen bolt holding the two pipes to the block.
mahunt is offline
post #7 of 7 (permalink) Old 05-24-2019, 09:48 AM Thread Starter
Vehicle: 95 SL600
Quoted: 8 Post(s)
took your advice. Called the dealership, and they are 2$ each. Had to come from germany, but the service guy said he put them on a priority order with some other parts he needed, so they will be here by next week. I went ahead and ordered a few extra just in case.
Thanks for the help gentlemen!
