Brittle breather hose etc replacement - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 05-17-2019, 04:39 PM Thread Starter
Date registered: Sep 2013
Vehicle: 1992 500SL, 1993 300SE, 1997 S320L, 2000 C230K, 2003 E500, 2005 Smart ForFour, 2008 Smart ForTwo
Quoted: 72 Post(s)
Iím replacing all my breather hoses as they are all brittle and cracked. I followed the parts list posted on here for the multiple hoses to replace.
Now it didnít mention replacing the fuel injector nozzle to the idle air hose.
Now the idle hose is harden it wonít slip off the fuel injector nozzle. Any one have any tips?
BenzWillMakeHerDance is offline
post #2 of 10 (permalink) Old 05-17-2019, 05:06 PM
bartsitarski's Avatar
Date registered: Jan 2014
Vehicle: 1998 SL500 Sport
Quoted: 75 Post(s)
Attachment 2513576
What hoses did you replace and do you have a link or a list of part numbers? I have to do the valve covers on my 98 M119 so they will need to be done too.
bartsitarski is online now
post #3 of 10 (permalink) Old 05-17-2019, 05:49 PM Thread Starter
Quoted: 72 Post(s)
As below
post #4 of 10 (permalink) Old 05-17-2019, 05:50 PM Thread Starter
Quoted: 72 Post(s)
I will post a proper list once Iím done as the one I found on here seemed to be a basic list which if I had other parts I can now see how much easier it will be rather than hacking away at hoses that wonít pull off a lip
post #5 of 10 (permalink) Old 05-17-2019, 06:27 PM
Quoted: 75 Post(s)
That is fair enough! Based on the state of the rubber bits on mine, I envision all of them will need to be done. Slowly but surely mine is getting a full refresh. Aside from the two things I mentioned, I need cam magnet seals redone, want to get the cats replaced because one is aftermarket and the other is rattling, and need to figure out where my rear clunk is coming from. Hoping itís a matter of reseating the subframe or exhaust hitting the subframe. With a three and four year old and a full + time job, hard to find the time to work on the car.
post #6 of 10 (permalink) Old 05-17-2019, 06:30 PM
260e crusier's Avatar
Date registered: Nov 2010
Vehicle: 1999 E320, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
Quoted: 486 Post(s)
Attachment 2513576
These make life easier:
https://www.harborfreight.com/3-piec...ers-37909.html
You can also slit the hose with a box cutter and then peel it off. Be VERY careful not to score the fitting inside the hose.
260e crusier is offline
post #7 of 10 (permalink) Old 05-18-2019, 02:59 AM Thread Starter
Quoted: 72 Post(s)
Yeah im not too sure if they would work to be honest, the hose was so hard and brittle I had to pick it apart with needle nose pliers, wasnt too bad but very time consuming and hard on the back.
post #8 of 10 (permalink) Old 05-18-2019, 03:18 AM Thread Starter
Quoted: 72 Post(s)
My car is a 1992 500sl
117-990-17-78 x 2No Air Hose "T" Connector
119-094-10-82 x 4No Air Distribution Hose (Left or Right)
119-094-11-82 x 4No Idle Air Hose - To Lower Part of Intake Manifold
119-094-12-82 x 1No Idle Air Hose - Idle Air Distributor To Intake Manifold,
119-094-13-82 x 1No Idle Air Hose - Idle Air Distributor To Intake Manifold (Right)
119-094-24-82 x 1No Breather Hose - Valve Cover To Air Filter,
119-990-00-78 x 4No Air Hose Connector for Intake Manifold (Connector Elbow)
Parts not replaced due to list on benzworld not noting them but also rubber and brittle
119 094 20 82 x 1No (part maybe superseded)
119 094 19 82 x 1No (part maybe superseded)
119-094-18-82 x 1No Idle Air Hose - Idle Speed Actuator To Idle Air Distributor
119-094-51-82 x 1No Air Hose - Air Duct to Air Slide Valve
Optional things to replace but involves other parts to be removed e.g injectors
116-070-00-77 x 8No Fuel Injector Seal
119-070-00-55 x 8No Nozzle Holder - Fuel Injector Nozzle
post #9 of 10 (permalink) Old 05-18-2019, 05:36 AM
Quoted: 75 Post(s)
Awesome. Thank you!
post #10 of 10 (permalink) Old 05-18-2019, 01:33 PM Thread Starter
Quoted: 72 Post(s)
Awesome. Thank you!
Also I must say I thought I had a misfire or something like that but the car idles very good now as in it feels like the engine isnít even running!!
Valve cover gasket and breather cover sealant DIY atmsmshr W220 S-Class 76 08-16-2018 12:08 PM
Under Hood Fuel Hose Replacement reno4u2 R/C107 SL/SLC Class 2 03-19-2016 07:51 AM
SLS high pressure hose Real1shepherd W124 E,CE,D,TD Class 62 06-15-2014 10:42 AM
Breather hose related items -- did you also replace these fittings? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 16 03-27-2008 08:45 PM
valve cover breather hose to top of air filter verisoph W126 S,SE,SEC,SEL,SD,SDL Class 5 02-15-2008 06:59 AM
