Bad fuse made me look like an idiot. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-15-2019, 07:25 AM Thread Starter
Date registered: Apr 2019
Vehicle: 95 SL600
Quoted: 8 Post(s)
Soooo...........
I drove the SL600 to work yesterday. No problems. Get in the car to head home, I noticed the roll bar light, the ADS light, ARS light, and ABS light were all on. I was a little concerned, but, I figured out I would check it out when I get home. The ARS and ABS light have been coming on once I start rolling about 10 mph or so. I had been chalking that up to the fact the guy I bought the car from had one size larger rear tires, or one of the wheel speed sensors was dead. But now there were on from the beginning.
So i start driving, about 5 min go by and the temp gauge is reading 40. Now im in panic thinking the thermostat is stuck closed. Not wanting to take any chances, I called AAA and had the car towed home.
Got it home, popped the thermostat out, and its just fine. So just for giggles I checked the fusebox, and wouldnt you know, one of those 25 year old crap fuses finally disintegrated all the way thru. Put a new fuse in, and all the lights went away and the temp gauge was working again.
I have no idea how that one fuse causes so much chaos on the gauges, but it does.
Sam Alfano is offline
post #2 of 3 (permalink) Old 05-15-2019, 07:30 AM
Date registered: Nov 2008
Vehicle: 1995 MB 600SL, !982 G-Wagen 280GE, BMW 1150RT
Hi, could you post photo of which fuse and where situated
Rudi Raaths is offline
post #3 of 3 (permalink) Old 05-15-2019, 07:36 AM Thread Starter
Vehicle: 95 SL600
Quoted: 8 Post(s)
I can later on today.
I can tell you it was the labeled instrument cluster in the engine bay fuse box.
The all new Joke thread eric242340 Off-Topic 2408 06-18-2019 08:42 PM
Mystery fuse outside of fuse box (not blower fuse)and seat heat chuckh0308 W124 E,CE,D,TD Class 3 09-02-2016 12:48 AM
I may have made bad mistake? Fatboy1 W126 S,SE,SEC,SEL,SD,SDL Class 10 09-24-2011 05:04 PM
Bad fuse kungfu W124 E,CE,D,TD Class 4 04-26-2005 07:15 PM
