windshield washer fluid temperature - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-13-2019, 06:20 PM Thread Starter
Date registered: Apr 2006
Vehicle: 1992 190E sportline, 1993 300ce, 1993 300ce sportline, 1997 sl320
Quoted: 8 Post(s)
I am not sure if I have a leak in the heating coils or thermostat in the windshield washer tank - and am losing fluid and no visible leaks. What should the temp of the ww fluid be when the car is at operating temp? Since I live in South Florida, think I can loop the lines and take the heater out as I hope never to need heated fluid. In order to see if it is leaking coolant into the ww tank can someone tell me the temp it should be at when the system is working properly? If it is too hot I have my answer and will make the necessary steps to correct.
sportlineguy is offline
post #2 of 7 (permalink) Old 05-14-2019, 04:54 AM
Date registered: Mar 2007
Vehicle: 2000 SL320, 2001 CLK320
Quoted: 366 Post(s)
It will reach the same temperature as the coolant - 85 deg C. In Florida you certainly do not need it, maybe in Alaska
rorypff is offline
post #3 of 7 (permalink) Old 05-16-2019, 01:07 PM
jstiles's Avatar
Date registered: Jul 2016
Vehicle: 1991 500SL
Quoted: 2 Post(s)
I am in So CA and had a thermostat leak in the washer reservoir. I could see the color difference in the fluid. I simply pulled the faulty hardware out and used copper pipe to bridge my coolant line outside of the washer reservoir. Its been over a year and now issues. My Indy said copper would be fine so I went with it.
Cheers!
jstiles is offline
post #4 of 7 (permalink) Old 05-16-2019, 01:30 PM Thread Starter
Quoted: 8 Post(s)
I think that is what I will do when I get the cooling issues settled. One less thing to worry about.....
post #5 of 7 (permalink) Old 05-16-2019, 01:31 PM
Frank_S500's Avatar
Date registered: Nov 2004
Vehicle: MB CL500(C215);SL55(R129), SL63(R230)
Quoted: 49 Post(s)
The heating coil has a thermoelement at the end so the water will never reach the coolant temperature, which would crack the windshield in winter...
Btw the element is sometimes stuck, leaving the washer reservoir cold...
To check wether there is a leak, just remove the water, and see if it fills with coolant...
Cheers, Frank
Live is too short to drive boring cars...
Frank_S500 is offline
post #6 of 7 (permalink) Old 05-17-2019, 04:22 AM
mahunt's Avatar
Date registered: Feb 2008
Vehicle: 1997 SL600 Brilliant Silver Sport with grey/dark metal interior, 234K miles
Quoted: 360 Post(s)
I saw where there were heating elements in the washer lines from the tank to the 2 squirters that's controlled by a module in the driver's side of the hood, but I always thought engine coolant was circulated unchecked through the stainless coil in the washer tank.
The washer lines have built in resistance wires that keep the lines from freezing during winter, but what controls the coolant flow to the stainless coil in the washer tank?
I guess I could check the washer tank temp after the car warms up to see how hot it gets.
mahunt is offline
post #7 of 7 (permalink) Old 05-17-2019, 06:41 AM Thread Starter
Quoted: 8 Post(s)
I used my infrared thermometer to check the wash tank fluid and it was @ 180 degrees - seems quite hot to me. Is this normal or what temp should it be kept at?
rorypff likes this.
Windshield Washer Fluid Can Harbor Deadly Bacteria AutoGuide.com AutoGuide.Com News 0 05-19-2014 09:50 AM
Windshield Washer Fluid Leak - Not The Grommet rudeney C209/A209 CLK-Class 0 07-12-2011 07:32 AM
Factory Windshield Washer Fluid easygreenus Detailing and Car Care 2 02-09-2007 07:46 PM
Heat turns on automaticly once car is started! bass1175 W140 S-Class 6 04-16-2005 05:54 PM
Windshield Washer Fluid Vincent W163 M-Class 5 12-12-2001 10:28 AM
