R129 replacement Bio-degradable harness availability - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 05-13-2019, 09:14 AM Thread Starter
Premium Member
MadColonel67's Avatar
Date registered: Dec 2012
Vehicle: 2004 E500 4Matic Wagon, 1980 450SLC, '94 SL500
Quoted: 30 Post(s)
Premium Member
I have replaced 2 out of 3 harnesses already and the 3rd one is really iffy, needs to be done and it is the big one. My dealer says that MBNA does not support them any longer so they aren't available. My tech says he can repair/wrap what he can see but that sounds like a fool's errand. What are we to do?
Michael Maddalena
Warren, CT
MadColonel67 is offline
post #2 of 14 (permalink) Old 05-13-2019, 11:40 AM
Date registered: Nov 2002
Vehicle: '82 500sec euro, '95 Ford F150
Quoted: 150 Post(s)
Which ones have you replaced and which is bad?
roadhouse is online now
post #3 of 14 (permalink) Old 05-13-2019, 11:45 AM Thread Starter
Premium Member
Quoted: 30 Post(s)
Premium Member
the part number is #1295402230.
Michael Maddalena
Warren, CT
post #4 of 14 (permalink) Old 05-13-2019, 11:49 AM
Quoted: 150 Post(s)
What number is that for? Upper, lower or MAF harness? Which one do you need?
post #5 of 14 (permalink) Old 05-13-2019, 01:54 PM Thread Starter
Premium Member
Quoted: 30 Post(s)
Premium Member
I am told it is the big one that runs underneath the car. The part number was verified by the Mercedes dealer.
Michael Maddalena
Warren, CT
post #6 of 14 (permalink) Old 05-13-2019, 01:58 PM
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
#22 on the diagram below
Mercedes-Benz Teilekatalog (Ersatzteile online)
Lower harness (starter, oil pressure and such) Definitely NLA, for a quality shop, its about $200-$300 to do it right.
Regards,
D
duh_vinci is offline
post #7 of 14 (permalink) Old 05-13-2019, 02:00 PM
duh_vinci's Avatar
Quoted: 252 Post(s)
Regards,
D
post #8 of 14 (permalink) Old 05-13-2019, 02:11 PM Thread Starter
Premium Member
Quoted: 30 Post(s)
Premium Member
Regards,
D
Thanks for the information. If it is NLA, how can it be repaired/replaced so inexpensively? Where does the new harness come from? I was told up to 10 hours to replace it IF there was a new harness available.
Michael Maddalena
Warren, CT
post #9 of 14 (permalink) Old 05-13-2019, 04:47 PM
duh_vinci's Avatar
Quoted: 252 Post(s)
If we are indeed talking about the lower harness (starter, oil etc), there is no way in hell it's 10 hours. I should have repaired mine when I had transmission out on SL500, but I was too concentrated on rebuilding that automatic box...
This would shine some light
https://www.benzworld.org/forums/r12...placement.html
To my best knowledge, there are 3 main harnesses that are affected (depending on the model of R129): Main upper, throttle body, lower starter harness. Few other pieces are (depending on the model again): MAF and electric cooling fans. Other affected pieces (usually, even later models) are headlight wires.
Hope this helps.
Regards,
D
post #10 of 14 (permalink) Old 05-14-2019, 04:19 AM
Quoted: 150 Post(s)
In 10 hours you would be able to MAKE a new harness AND replace it. The lower harness is only 5 or 6 wires, out of which the heavy battery cable usually doesn't even need replacing. (It came with non degrading insulation)
It consists of oil pressure wire, low oil level wire, alternator exciter wire, charge on alternator, starter and starter coil wires.
Of the three degrading harnesses, this is the easiest to replicate.
Issue after wiring harness replacement on a 94 C220 JohnMc03 W202 C-Class 9 04-28-2016 11:25 PM
'93 300E Engine Wiring Harness Replacement jervonics2112 W124 E,CE,D,TD Class 12 07-15-2011 08:19 PM
1993-1995 Engine wiring harness problems bcool R129 SL-Class 107 12-29-2009 11:43 PM
Wiring Harness Replacement.... Cyberbach W124 E,CE,D,TD Class 10 10-13-2005 08:31 AM
wiring harness replacement snik W140 S-Class 4 07-06-2004 12:04 PM
