R129 replacement Bio-degradable harness availability - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 05-14-2019, 12:07 PM Thread Starter
Premium Member
MadColonel67's Avatar
Date registered: Dec 2012
Vehicle: 2004 E500 4Matic Wagon, 1980 450SLC, '94 SL500
Quoted: 30 Post(s)
Premium Member
Originally Posted by roadhouse View Post
In 10 hours you would be able to MAKE a new harness AND replace it. The lower harness is only 5 or 6 wires, out of which the heavy battery cable usually doesn't even need replacing. (It came with non degrading insulation)
It consists of oil pressure wire, low oil level wire, alternator exciter wire, charge on alternator, starter and starter coil wires.
Of the three degrading harnesses, this is the easiest to replicate.
This is what I learned - My VIN for the '94 SL500 used harness #1295402230. Only 2800 units used that harness and I am told, the reason why it is no longer supported. There were earlier harnesses and later harnesses for the SL500 - #1295402630 (available in Germany) and #1295400530 (available stateside). The diagrams for all 3 look similar if not the same. It could be a connector that is different or some other minor adjustment. So, I ordered the stateside harness and my mechanic will remove the old harness and see what has to be modified and then reinstall. I am told the remove and reinstall should be 4 to 6 hours labor.
I hope this helps fellow bio-degradable owners of SL500s.
Michael Maddalena
Warren, CT
MadColonel67 is offline
post #12 of 14 (permalink) Old 05-14-2019, 05:56 PM
Date registered: Nov 2012
Vehicle: 1995 SL500-129
Location: Blackheath, in the Blue Mountains NSW Australia
Quoted: 25 Post(s)
The oil pressure harness is what I require. Does anyone have it? 1995 sl500 R129. I need it urgent as I have to sell the car to support my 2 grand son's 4 and 6 year olds. Thanks Rob
Ozzie Rob is offline
post #13 of 14 (permalink) Old 05-14-2019, 06:15 PM
Quoted: 25 Post(s)
Actually just googled the part # for the oil harness, and that is not the one I require. It is the one where it starts at the ECU and not the one for the injection. Also, does anyone know what that magnetic switch is for the soft top that is located above the front windscreen is called, or a part#. Thanks, Rob
post #14 of 14 (permalink) Old 05-26-2019, 03:26 PM Thread Starter
Premium Member
Quoted: 30 Post(s)
Premium Member
Here is the latest. The old bio-D harness came out and as it turns out, the part #1295400530 required very minor alteration to fit. It went back in with a total of 4.5 hours r/reinstall. So, if you have a VIN
that says your harness is not available anymore, keep looking at harnesses until you find a close match.
Michael Maddalena
Warren, CT
Issue after wiring harness replacement on a 94 C220 JohnMc03 W202 C-Class 9 04-28-2016 11:25 PM
'93 300E Engine Wiring Harness Replacement jervonics2112 W124 E,CE,D,TD Class 12 07-15-2011 08:19 PM
1993-1995 Engine wiring harness problems bcool R129 SL-Class 107 12-29-2009 11:43 PM
Wiring Harness Replacement.... Cyberbach W124 E,CE,D,TD Class 10 10-13-2005 08:31 AM
wiring harness replacement snik W140 S-Class 4 07-06-2004 12:04 PM
