window auto drop question - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-09-2019, 03:50 PM Thread Starter
Date registered: Apr 2006
Vehicle: 1992 190E sportline, 1993 300ce, 1993 300ce sportline, 1992 300sl
Quoted: 8 Post(s)
Does a 1992 330/500sl have the window auto drop function - @1/4 inch when you open the door and auto rise the same @ 1/4 inch? I have read the forums and it seems that the later 1994/95 and on have this feature. I have done the sync procedure and it does not seem to make any difference. The hardtop and soft top and roll bar function properly so I wonder if this feature even exists on this model year. Any ideas appreciated
sportlineguy is offline
post #2 of 7 (permalink) Old 05-09-2019, 04:31 PM
Date registered: Jan 2004
Vehicle: '03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
Quoted: 561 Post(s)
Cars made in calendar year 1993 or earlier do not have window drop-down. I believe the drop feature was necessitated by a redesign of the window seal which featured a deeper "v" groove.
roadhouse and Ears like this.
bobterry99 is offline
post #3 of 7 (permalink) Old 05-13-2019, 08:41 AM
Date registered: May 2014
Vehicle: 1993 Mercedes SL500 & 2010 Mercedes GL450
Quoted: 19 Post(s)
93 500sl here and mine drop!
simongunz is offline
post #4 of 7 (permalink) Old 05-13-2019, 11:29 AM
Quoted: 561 Post(s)
I knew a guy who used to buy two wrecked examples of a particular car: one was hit in the back, the other in the front. He'd cut each car in half and weld together the two halves to make one "good" car and sell it without revealing what he had done.
They shouldn't. You may want to investigate the possibility that your car's VIN is not original to the chassis.
This is incorrect:
The drop-down feature was introduced early in MY1995 (December, '94). See here ("Test Step" 11.0): STAR TekInfo.
post #5 of 7 (permalink) Old 05-20-2019, 10:21 AM
Date registered: Nov 2016
Vehicle: 1991 500SL
Quoted: 13 Post(s)
Well is it possible to retrofit this feature to earlier cars that don't have it? And if so what would be required in order to retrofit this feature?
AG129 is offline
post #6 of 7 (permalink) Old 05-20-2019, 11:38 AM
ChipThome's Avatar
Date registered: Apr 2019
Vehicle: 1995 and 1996 SL320 One Keeper One For Sale
Quoted: 34 Post(s)
While investigating some windows issues I am having with my 96 I have learned a lot of their functions are run through the top controller module.
ChipThome is offline
post #7 of 7 (permalink) Old 05-21-2019, 04:04 PM
Quoted: 561 Post(s)
You would need the motor assemblies, roof controller, and electrical connectors, and then you'd have to wire it all to make it work. And if your car is fitted with its original window seals, the entire effort would be absolutely pointless.
Soft top window kit installation cushjbc R/C107 SL/SLC Class 29 05-11-2015 02:34 PM
Coupe rear window question ch.1953 W140 S-Class 4 11-13-2012 06:02 AM
R129 window Auto Drop rocketfixer R129 SL-Class 9 10-07-2012 04:08 PM
W124 Auto Up/Down Window - Can it be done ? stormtigers W124 E,CE,D,TD Class 11 07-10-2011 02:51 AM
Window switch question... Ogre W124 E,CE,D,TD Class 5 05-28-2007 12:02 PM
