98 SL500 Window clunks at bottom - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-01-2019, 08:39 PM Thread Starter
FATHERTIME's Avatar
Date registered: Aug 2015
Vehicle: 94 SL320 98 SL500 99 SL600
Quoted: 234 Post(s)
My 98 SL500 had a windows clunk when lowering them. I replaced both regulators and that fixed the issue however after two months the drivers side is doing it again, a loud clunk when window hits bottom, the passenger side is fine. What can be the problem, did something break or fall off?
John;
FATHERTIME is online now
post #2 of 5 (permalink) Old 05-04-2019, 03:30 PM Thread Starter
FATHERTIME's Avatar
Quoted: 234 Post(s)
So after combing through hundreds of posts I read about an adjustment for the clunk and sure enough that was the problem. All fixed now.
John;
post #3 of 5 (permalink) Old 05-04-2019, 03:47 PM
Date registered: Sep 2018
Vehicle: 1999 SL500, 1998 SL500
Quoted: 2 Post(s)
Can you share the post or the steps you took to fix the clunk? I have a 1998 with the same issue. Thanks!
SigKev is offline
post #4 of 5 (permalink) Old 05-04-2019, 04:02 PM Thread Starter
FATHERTIME's Avatar
Quoted: 234 Post(s)
Take off door panel and about half way up the door pull back the plastic and in the area of the rivets there is a large T30 Torx bolt going through a slot on the regulator. Raise the window and loosen the bolt then drag it to the rear of the door, you need to tighten it pretty good. Then check the auto window when down see if you can get it so it's still in the weather strip when all the way down.
John;
post #5 of 5 (permalink) Old 05-04-2019, 04:21 PM Thread Starter
FATHERTIME's Avatar
Quoted: 234 Post(s)
Here is a pic of the bolt. Just to the left of the gold colored panel bracket.
John;
Power window problem in W124 (300D Turbo '92) Guest (MBNZ) W124 E,CE,D,TD Class 3 01-03-2015 07:08 AM
Loud driver door clunk when window reaches bottom cab1ho R129 SL-Class 5 05-09-2014 09:42 AM
Help! How to R&R power window motor on 1995 SL500 a95Sl500owner R129 SL-Class 11 02-15-2013 05:11 PM
Comment About Rear Window Regulator Replacement CL600Mikey W210 E-Class 10 10-11-2012 08:37 PM
Window blowing fuses R129 SL500 1998 gnatharris R129 SL-Class 4 11-10-2008 05:42 AM
