Re: R129/W140 instrument cluster - Page 2 - Mercedes-Benz Forum
post #11 of 42 (permalink) Old 04-29-2019, 01:43 PM
Date registered: Nov 2002
Vehicle: '82 500sec euro, '95 Ford F150
Quoted: 148 Post(s)
Goes without saying, that I’ve wiped the excess tire wet after the application, so it never looked greasy, or shiny. The matt black paint absorbed most of it quite quickly.
roadhouse is offline
post #12 of 42 (permalink) Old 04-29-2019, 03:52 PM Thread Starter
Chicky's Avatar
Date registered: Apr 2007
Vehicle: 1991 R129 500SL
Quoted: 100 Post(s)
Thumbs up
Originally Posted by guzzimike View Post
There was a thread about this type Instrument Cluster a few years ago ( 2011 or 2012 ), and IIRC the price for it back then was around $400 US.
The part Number was also included, as was the seller.. I think it might have been Parts.com, but I'm not sure.
You may want to do a search here under "Silver Arrow instrument cluster" and similar.
Good luck to you.
Hi guzzimike,
Thank you for this info, I'll do a search on this in a while.
Chicky is offline
post #13 of 42 (permalink) Old 04-29-2019, 03:59 PM Thread Starter
Chicky's Avatar
Quoted: 100 Post(s)
Thumbs up
Originally Posted by roadhouse View Post
I washed mine out with dish soap and water. After it dried, it the spots went away for the most part, but they became visible in some areas. I then sprayed foaming tire wet on a paper towel and rubbed it on the black part in a few applications. Then I cleaned the glass from the inside.
The spots have not come back yet in the three years Iíve owned my w140.
Hi roadhouse,
I will definitely tryout your procedure on the "sacrificial cluster"...keeping my fingers crossed that I'll get the same results.
Thank you
Chicky is offline
post #14 of 42 (permalink) Old 04-29-2019, 04:14 PM Thread Starter
Chicky's Avatar
Quoted: 100 Post(s)
Red face
Hello Gentlemen,
I just a call from my indie mechanic, that removal of the clear lens from the cluster housing, was successful but he ended up having a crack on the lens. But he noted that, if he were to do the same procedure on my car's cluster, in all probability, he would be able to take it off without any damage ...hmmm
Also, I was rethinking the option of buying the Silver Arrow version instrument cluster housing, not because of the projected $$$ that it costs, but in my humble opinion, "too blinggy" ...I'm on the fence on this option.
Another option is to buy a new cluster housing meant for my model year, then fit the new set of chrome rings I have lying around. However, the dreaded white spots occurring sometime down the line, is a possibility ... due to the humidity factor (I'm located in a tropical country)...also notwithstanding always having 3 packs of dehumidifiers inside the car, which is always garaged (roofed) + a car cover
Chicky is offline
post #15 of 42 (permalink) Old 05-01-2019, 01:36 AM Thread Starter
Chicky's Avatar
Quoted: 100 Post(s)
Talking
Just wanted to update on the status of this:
I just got back today, the cluster housing and cracked clear lens (which by the way, there is no sure fire way of removing from the cluster housing without cracking the lens, due to being fuse-welded into place )
This coming weekend, I'll try roadhouse's method and will report back on the results + pics
So as off today, here are my options:
A. Buy a new R129 instrument cluster housing, meaning $$$...but I fear that it will eventually get the
same dreaded white spots in the future, being located in a tropical country and having high humidity.
B. Buy the Silver Arrow cluster housing, meaning $$$$...but I still fear that it will also have the dreaded
white spots on the black portion of the cluster housing.
C. "Hoping and praying" roadhouse's methods will work out (and I really hope it does )
D. Don't make an issue of the white spots and disregard ...but being O/C...really hard
Chicky is offline
post #16 of 42 (permalink) Old 05-01-2019, 01:21 PM
Vehicle: M113 SL500
Quoted: 156 Post(s)
Since you already have a broken cluster front housing, maybe you can experiment with some thin lexan? I've never tried forming a piece of lexan, but I think a thin sheet would be pretty easy with a heat gun. Then seal it with silicone. Holes can be drilled with light pressure and slow speed to prevent cracking.
brauhaus is offline
post #17 of 42 (permalink) Old 05-01-2019, 02:16 PM Thread Starter
Chicky's Avatar
Quoted: 100 Post(s)
Smile
Hi brauhaus,
The broken clear lens was from my "experimental" cluster housing that I wanted to practice on...before trying to remove my car's original cluster lens.
But you do have a good option there. I haven't tried "g" regarding Lexan and searching if they have a thin (as in 2 or 3mm thick) clear polycarbonate sheets.
Thank you for your suggestion.
Chicky is offline
post #18 of 42 (permalink) Old 05-02-2019, 12:30 AM
ChipThome's Avatar
Date registered: Apr 2019
Vehicle: 1995 and 1996 SL320 One Keeper One For Sale
Quoted: 43 Post(s)
It looks like the hot trend on customizing one's car is wrapping it. Would maybe getting the black face wrapped in a matte black do anything to solve you dreaded white spotting?
ChipThome is online now
post #19 of 42 (permalink) Old 05-02-2019, 02:15 AM
BAHRAINI AMG's Avatar
Date registered: Oct 2012
Vehicle: 1999 SL500
Quoted: 40 Post(s)
Well, I just thought I should share my experience with regards to instrument clusters.
I recently bought a Euro instrument cluster from a friend, this cluster came off a 1998 W140.
I own a 1999 US spec R129.
So naturally, I thought a direct swap would work just fine, understanding very well that my car will display a different odometer reading as the W140 had a lower mileage.
Well, a direct swap didn't work, all the dials worked, however, the LCD display did not.
My electronics guy tried checking all cables and components, nothing was out of the ordinary.
So my guess is, cluster swap is possible but odometer display will not work.
Thought I should share this info in case someone asks.
Now, coming to your issue, if you require parts for your cluster, I have them.
The only parts I used from the W140 cluster were the dial faces. Everything else is in good condition if you're interested.
2016 Lexus GSF
1999 Mercedes Benz SL500
1993 Dodge Viper RT/10
BAHRAINI AMG is offline
post #20 of 42 (permalink) Old 05-02-2019, 07:10 AM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1997 SL500- 40th Anniversary
Quoted: 500 Post(s)
Also, be advised the w140 cluster will not have the roll bar MIL, etc. this doesn’t matter if all you want is the bezel. I have heard SDS may be able to marry cluster so LCD might come back. Strictly speculation.
A Specialist is needed to “change” mileage with caveats of potential disaster... o understand the chip set has to be harvested and swapped.
Best Regards...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
instrument cluster stopped working now trouble code P0700 Tyrone Williams W163 M-Class 23 08-23-2016 09:50 PM
ML320 Instrument Cluster replacement Dave0r W163 M-Class 4 11-09-2015 11:04 AM
94 c220 diesel instrument cluster problem!. gudikcik W202 C-Class 3 04-17-2011 01:22 PM
W201 Instrument Cluster Removal Instructions raed_jan W201 190-Class 18 06-20-2009 07:23 PM
'CAN' instrument cluster fault darraghodonnell R129 SL-Class 9 04-30-2009 03:57 PM
