Vacuum block issue - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-19-2019, 03:58 AM Thread Starter
Date registered: Feb 2019
Vacuum block issue
My center air vents some times closes while driving , long story short i found a crack in the vacuum block , i ordered a new one , the issue. Is i found un connected vacuum line
Can anyone identify this hose and where it should go
Coolice232 is offline
post #2 of 3 (permalink) Old 04-19-2019, 04:00 AM Thread Starter
These are the pics
ID:	2505768   Click image for larger version
ID:	2505770   Click image for larger version
post #3 of 3 (permalink) Old 06-18-2019, 11:08 PM
Lawrencefitzsimon's Avatar
Vehicle: '85 380SL, '99 SL500, '18 C300, '78 911SC, '91 Alfa Spider
Quoted: 20 Post(s)
I believe this is the hose that leads to your intake manifold. I’ll double check in the morning and let you know. It goes through the firewall closer to the driver’s side.
Lawrencefitzsimon is offline
Another cracked vacuum distribution block Ruindr R129 SL-Class 31 07-14-2019 02:27 PM
Vacuum Lock Issue jacquesblom W123 E,CE,D,CD,TD,TE Class 10 05-26-2016 07:51 AM
81 300CD Vacuum / transmission issue....... imdji W123 E,CE,D,CD,TD,TE Class 6 08-24-2010 06:53 PM
Intermittent vacuum issue. akimball442 W123 E,CE,D,CD,TD,TE Class 3 03-08-2009 10:39 AM
Guess it's my turn to have a vacuum issue MBeige W123 E,CE,D,CD,TD,TE Class 14 04-30-2008 09:04 PM
