Cruise Control Issue - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 04-16-2019, 04:28 PM Thread Starter
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1997 SL500- 40th Anniversary
Quoted: 514 Post(s)
I hate electrical (then why did I sell a 107 and buy a 129?), especially intermittent electrical glitches. Let me first say I suffer from a condition that, perhaps some of you can relate... no-ass-atall! Sitting for long periods is uncomfortable, especially so in European and Japanese seats (My ford Ranger and my mom's Chry 300, 100% no problem, but the 129 and my LS, owiee), so I move my legs and shift in the seat quite a bit. Imagine my disappointment then, when I jumped in the 129 today, let down the hood, and hit the highway for home (100 miles away) and the cruise control didn't work. It has never glitched before, and worked flawlessly this morning on the way in... Dammit! Well, I finally gave up and had to pull over at a rest stop 50 miles later, to stretch the ole legs. After starting back up and merging onto the super-slab, I tried the cc once again for kicks... It worked flawlessly!
One question before I drag out the old SDS system and while my time away, does a '97 integrate the cc into the fuel management computer like later cars?
Fun, Fun, Fun...
Best Regards...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #2 of 11 (permalink) Old 04-16-2019, 05:05 PM
Administrator
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 859 Post(s)
Usually this happens when tyres are changed and the diameters are different on each axle.
As this isn't the case, could it be something silly like tyre pressure down on one wheel?
No trees were harmed creating this message, however some electrons were very inconvenienced.
RedLiner is offline
post #3 of 11 (permalink) Old 04-16-2019, 05:21 PM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 749 Post(s)
Or dirty wheel speed sensor ?
RKH is offline
post #4 of 11 (permalink) Old 04-27-2019, 06:44 AM
Date registered: Apr 2019
Vehicle: 1991 300 sl
Quoted: 2 Post(s)
Send a message via Skype™ to jimrogers74@comcast.net
i am having the same w/ my 91 300 sl. curious what the solution is.
post #5 of 11 (permalink) Old 04-27-2019, 09:24 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
Quoted: 596 Post(s)
I'll guess the problem us the electronic module for the cruise control.
I'd check all of the inputs to the controller and verify their validity using a multimeter. The diagnostic manual can guide you through those tests.
Presuming they are fine, next I would search the W124 forum for threads describing module repair. At a minimum I believe you will find a member who repairs these modules, and you may even find how to repair it yourself.
bobterry99 is offline
post #6 of 11 (permalink) Old 04-28-2019, 07:17 AM Thread Starter
Ears's Avatar
Quoted: 514 Post(s)
Update
After several short jaunts, and a recent 300 miler, my cruise has performed flawlessly... Chock it up to another intermittent fault which, i am sure, will return someday. until then, I'll motor along...
Best Regards...
RM Smith
Ears is offline
post #7 of 11 (permalink) Old 05-04-2019, 09:28 PM
cheezhead's Avatar
Date registered: May 2018
Vehicle: 2000 SL 500
Having the same issue with mine, only I'm now beyond the intermittent stag, just doesn't function at all.
cheezhead is offline
post #8 of 11 (permalink) Old 05-05-2019, 04:57 AM
Quoted: 596 Post(s)
Originally Posted by cheezhead View Post
...just doesn't function at all.
You might go through the electrical schematics and check the plausibility of all inputs to the engine management computer which relate to the cruise control. I'd start with the brake switch. Better still, invest $300 in a Star Diagnosis diagnostic kit from alixepress.com to investigate your problem.
post #9 of 11 (permalink) Old 06-23-2019, 08:38 PM
cheezhead's Avatar
Took my SL 500 to a reputable German shop and they ran diagnostics, cleared some old codes and CC worked perfectly, next day I got a check engine light, CC still worked fine, after a few trips the check engine light cleared and the CC doesn't work again. Tires are correct and properly inflated.
post #10 of 11 (permalink) Old 06-24-2019, 01:10 PM
Doohan's Avatar
Date registered: Nov 2005
Vehicle: SL500 R129 1994
Quoted: 30 Post(s)
I'd do as RKH says, clean all the abs pickups sensors and the axle gears that such sensor read. They are usually very dirty and rusty, particularly on a 28 years old car.
Doohan is offline
cruise control issue - help! Vladdd C215 CL-Class 5 02-18-2018 03:56 AM
Mercedes Fault Codes... These Will Get You Out Of Trouble......one Day ! ;) Sarge786 V-Class 53 10-22-2017 01:19 PM
1998 E 320 cruise control and turn signal switch issue Nomad13 W210 E-Class 4 10-02-2016 09:41 AM
Bosch KE-Jetronic Overview isthisdave R/C107 SL/SLC Class 16 11-20-2012 03:33 PM
Useful links 4 new members - repost Bazzle R170 SLK-Class 79 02-06-2011 09:45 PM
