1996 SL320 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old Yesterday, 02:05 PM Thread Starter
Date registered: Jul 2004
Vehicle: 1996 SL320
Quoted: 13 Post(s)
1996 SL320
Good day, 70,500 miles only driven in perfect weather conditions. Have noticed a clunk sound when standing still if steering wheel is turned quick snap left or right. Does that indicate the universal in the steering column has excess play or something else to consider in linkage. I replaced the steering damper already. Thank you, Dorian
DORIAN is offline
post #2 of 3 (permalink) Old Yesterday, 04:04 PM
bartsitarski's Avatar
Date registered: Jan 2014
Vehicle: 1998 SL500 Sport
Quoted: 66 Post(s)
Could be anything. Ball joints, tie rods, strut mounts, pitman arm bushing loose steering box, loose bearings... lift the car and start playing with the wheels to see if there is play. Also, if any of the parts are original, you may want to think of replacing due to age, not mileage.
bartsitarski is offline
post #3 of 3 (permalink) Old Today, 01:28 AM
robm.UK's Avatar
Date registered: Jun 2009
Vehicle: R129 500 SL 1991
Quoted: 263 Post(s)
Lift each front wheel off ground. Grab tire 9 & 3 o’clock position. Pull/push each side. Then 12 & 6 o’clock. There should be small (tiny) amount of movement in front bearing. But if you feel more movement (looseness) 9 & 3, most likely worn tie rod end ball joints.
Worn idler arm bush can exhibit knocking while going over speed bumps etc., but not normally when stood still turning wheel.
Steering boxes have some free play by design. Maybe you’re hearing the slack in the box. Check radial seals are not leaking power steering fluid. Wet Pitman arm. R&R seals as necessary. Replace outer and inner seals. Not just outer.
robm.UK is online now
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ceta4zng
1996 r129 sl320 hagar 27 R129 SL-Class 2 08-15-2015 03:42 PM
1996 SL320 radiator replacement fillup R129 SL-Class 0 05-17-2012 01:59 PM
Help buying, 1996 SL320 baco99 R129 SL-Class 9 08-08-2005 06:34 PM
Importing my 1996 sl320 into Canada kmcaffer R230 SL-Class 1 06-28-2003 11:11 PM
Importing my 1996 SL320 into Canada kmcaffer R129 SL-Class 3 06-28-2003 05:39 PM
