changing rear flex disc - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-14-2019, 07:48 AM Thread Starter
Date registered: Apr 2006
Vehicle: 1992 190E sportline, 1993 300ce, 1993 300ce sportline, 1992 300sl
Quoted: 8 Post(s)
Is changing the rear flex disc as easy as unbolting the old one and prying it out and then inserting the new one and bolting it in aligned properly and correctly bolting it in? No need to loosen anything else for this process? This is for a 1992 300/500sl.
Thanks
sportlineguy is offline
post #2 of 5 (permalink) Old 04-14-2019, 08:07 AM
bartsitarski's Avatar
Date registered: Jan 2014
Vehicle: 1998 SL500 Sport
Quoted: 72 Post(s)
From all the videos I have seen, that is correct. Just make sure to mark the shaft and diff so it bolts back in the same spot.
bartsitarski is online now
post #3 of 5 (permalink) Old 04-14-2019, 09:45 AM
Administrator
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 818 Post(s)
It wasn't easy on my 1993 SL500 .
My flex discs are the 8 bolt type, and the rear disc could not drop down for inspection. I did it all up again and replaced both discs at a later date when I had to drop the exhaust to access the shaft and two discs.
No trees were harmed creating this message, however some electrons were very inconvenienced.
RedLiner is offline
post #4 of 5 (permalink) Old 04-15-2019, 03:38 AM Thread Starter
Quoted: 8 Post(s)
My 1992 300sl has the 6 bolt flex disc, wonder if that makes any difference?
post #5 of 5 (permalink) Old 04-15-2019, 04:10 AM
robm.UK's Avatar
Date registered: Jun 2009
Vehicle: R129 500 SL 1991
Quoted: 270 Post(s)
As RedLiner says. Drop exhaust.
Then you can either slacken off the large drive shaft nut and loosen central bearing to allow the shaft to slide back OR you lower the diff (3 bolts) about 4 on a jack and slide the diff back to allow you to R&R flex disk safely.
robm.UK is offline
E320CDI - labor cost for rear flex disc and front upper control arm picture this W211 E-Class 2 01-06-2017 07:08 PM
Front and rear flex disc? MichaelBenz300e W124 E,CE,D,TD Class 5 10-17-2014 12:22 PM
Replacing rear flex disc on '02 E430 sr71blkbrd W210 E-Class 9 09-12-2014 01:08 PM
C36 AMG flex disc replacement (Check yours now) toptoad W202 C36 AMG, C43 AMG 1 01-03-2013 08:48 AM
Rear Flex Disc and Driveshaft Support Bearing Location('96 C220)? Propaganda W202 C-Class 5 01-01-2010 09:11 PM
