Hard Top DIY: Panels, Headliner and Anatomy - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 04-07-2019, 05:17 PM Thread Starter
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
Red devil project continues... Interior is now probably one of the best pre-face lift I've seen, and I'm very happy with the progress, very very tidy!!! Downfall is the hard top: Peeling vinyl from the side panels, and the typical sagging headliner. Time to re-do it all. I got a great deal on a full cow hide, and that is what I'm going to use on the panels, factory vinyl has shrunk beyond repair...
full_leather by Duh_Vinci, on Flickr
I do have a spare roof, originally meant to go to a friend, but he sold his R129 and this roof is back in my garage. So while it's off the car, now is as good time as any to work on re-doing all the panels (then, I will swap all that into my roof), headliner and share the "anatomy" for any anyone who's planning on doing the same.
Fine Philips screws (10 total, x4 on the back panel, x3 at each side panel)
20190407_153743 by Duh_Vinci, on Flickr
Forward edge just pressure fitted to the roof at these 3 points
20190407_184504 by Duh_Vinci, on Flickr
At the rear edge, these 3 points...
20190407_184709 by Duh_Vinci, on Flickr
...slide into these metal clips
20190407_184603 by Duh_Vinci, on Flickr
The single golden clip fits into this opening of the plastic panel (arrow)
20190407_154830 by Duh_Vinci, on Flickr
Once the side panels removed, the rear lower trim can simply be lifted (held in place by the white tabs in the picture above - note, that most likely, they are no longer attached to the panel, glue just deteriorates over time)
On to the headliner... This particular roof is a first generation version, with no window drop. The main difference is the front rubber trim, not attached with the screws and wide metal panel, but instead, 5 pressure fitted clips:
20190407_185217 by Duh_Vinci, on Flickr
And closer view
20190407_185148 by Duh_Vinci, on Flickr
Then, entire rubber gasket is removed (note, carefully lift both corners from under the main seal)
"Ohh $hit" handles, move the trim ring upwards,
20190407_185041 by Duh_Vinci, on Flickr
Peel back the flap, remove the 8mm screws and remove the handles.
20190407_185057 by Duh_Vinci, on Flickr
Now, the headliner is ready to be removed by sliding it forward. More tomorrow (brittle mounting points repairs)...
Regards,
D
Ears, MAVA, LAMike240 and 1 others like this.
duh_vinci is offline
post #2 of 12 (permalink) Old 04-08-2019, 06:27 PM Thread Starter
duh_vinci's Avatar
Quoted: 252 Post(s)
Little more progress, all the broken plastic pieces are fixed. R129's best friend (along with JB Weld epoxy):
20190407_181548 by Duh_Vinci, on Flickr
This stuff is amazing when it comes to sculpting things... Start with this
20190407_175636 by Duh_Vinci, on Flickr
First layer, mesh and another layer over the mesh afterwards
20190407_181810 by Duh_Vinci, on Flickr
Send down
20190408_175822 by Duh_Vinci, on Flickr
Sculpt the recessed opening for the screws
20190408_181039 by Duh_Vinci, on Flickr
Next the leather skin to work with...
Regards,
D
roadhouse, wayneg, Bill SD and 2 others like this.
post #3 of 12 (permalink) Old 04-09-2019, 10:03 PM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1233 Post(s)
Nice work as always with your cars. You have this touch for these cars..
Martin
duh_vinci likes this.
MAVA is offline
post #4 of 12 (permalink) Old 04-11-2019, 09:46 AM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 270 Post(s)
Nice repair work duh_vinci,
For sculpting repairs, to match the finished texture of any surface, leather and even dashboards, Ive used a mohawk finishing grain mold compound to duplicate the finished surface.
khomer2 is offline
post #5 of 12 (permalink) Old 04-13-2019, 03:04 PM Thread Starter
duh_vinci's Avatar
Quoted: 252 Post(s)
Martin
Cheers Martin! Labor or love, you know it! Next project - carbon fiber trim to replace the wood, looked up your old thread, needed a little more inspiration, got what I needed from looking at your work! And got the "oddest" carbon fiber I could find imo, will not be "approved" by many, but I think it will look badasssss... Soon!
Cheers, and indeed great stuff! Perfect for those delicate, visible surfaces to be restored. Fortunately, these panels are only textured to hold the glue in place, so less work for me!
Regards,
D
post #6 of 12 (permalink) Old 04-13-2019, 04:23 PM Thread Starter
duh_vinci's Avatar
Quoted: 252 Post(s)
All done, at last!
Corners and indentations on these panels, the multidimensional shapes ended up bit more challenging than I anticipated, one must appreciate the quality of lifetime craftsman doing this type of work for fine automobiles... You have to be able to feel and know the leather, kinda like metal work... Not easy by any means, but very very rewarding!
20190408_183846 by Duh_Vinci, on Flickr
Original color of leather was blue black, imperfect coloring, hence $50 for full hide.
20190408_203442 by Duh_Vinci, on Flickr
Dyed in black to match the rest of the interior
20190413_174200 by Duh_Vinci, on Flickr
20190413_174351 by Duh_Vinci, on Flickr
20190413_185511 by Duh_Vinci, on Flickr
I like the texture, perfect deep black matching color. Very happy with results overall!
Regards,
D
Bill SD and AroundTheBenz like this.
post #7 of 12 (permalink) Old 06-15-2019, 04:12 PM Thread Starter
duh_vinci's Avatar
Quoted: 252 Post(s)
While the car is in the body shop getting new paint, mind as well finish the headliner. Another one for the books (this one is #4 for R129) - synthetic "alcantara"
This summer need to take care of my W202, it finally sagged... Will start after finishing this car.
Regards,
D
P.S. This video is rather helpful for the first time DIY
post #8 of 12 (permalink) Old 06-16-2019, 10:54 AM
FATHERTIME's Avatar
Date registered: Aug 2015
Vehicle: 94 SL320 98 SL500 99 SL600
Quoted: 234 Post(s)
Originally Posted by duh_vinci View Post
While the car is in the body shop getting new paint, mind as well finish the headliner. Another one for the books (this one is #4 for R129) - synthetic "alcantara"]
Are you painting the entire car. Are you changing color?
John;
FATHERTIME is offline
post #9 of 12 (permalink) Old 06-16-2019, 11:02 AM Thread Starter
duh_vinci's Avatar
Quoted: 252 Post(s)
Yes Sir, full respray, including the spoiler, front and rear aprons and the hard top. Keeping the factory color, I don't see many red R129 cars anymore, and the ones I see all clear is peeling...
Should have it back home next week and looking factory new
Regards,
D
FATHERTIME likes this.
post #10 of 12 (permalink) Old 06-16-2019, 11:07 AM
FATHERTIME's Avatar
Quoted: 234 Post(s)
Yes Sir, full respray, including the spoiler, front and rear aprons and the hard top. Keeping the factory color, I don't see many red R129 cars anymore, and the ones I see all clear is peeling...D
I'm guessing you striped is yourself?
John;
