Weak blower even after regulator replacement - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 03-30-2019, 10:22 AM Thread Starter
Date registered: Mar 2014
Vehicle: 97 SL600 Pano, ex: 96 (late 95) SL320
Quoted: 22 Post(s)
I recently replaced the blower motor regulator with the help of Gadha's excellent DIY guide. The original problem was that after an hour or so of driving, the air flow from the blower got very weak. After replacing the regulator all seemed well, but a couple of months went by when I only drove very short distances.
Today I drove a bit longer. The weather here is starting to resemble something like spring (finally), and I noticed at some point it's getting a bit hot in the car. I soon realized the blower wasn't doing that good of a job even at max speed. It was blowing cold, but the air flow was far from what it should be. Later, after the car had cooled down, I tried again and it was much better.
Did I buy a bad regulator or could it be something else, like the blower motor itself? I've understood problems with the motor usually cause either intermittent operation (on/off) or noisy operation etc, while the symptoms I'm seeing are more typical of a bad regulator that acts up when it heats up.
The regulator I bought was from eBay from a seller in the UK. It was new, probably a Chinese product, just the regulator without a heat sink. Are there sellers or brands that are known to be good? Or bad, for that matter.
juuso is offline
post #2 of 16 (permalink) Old 03-30-2019, 10:47 AM Thread Starter
Quoted: 22 Post(s)
One more thing to add: there was a tube of thermal paste included with the regulator and I applied an appropriate amount of it. I'm a software engineer now but in my teens I built more than my fair share of PCs so that stuff is something I'm quite familiar with...
juuso is offline
post #3 of 16 (permalink) Old 04-02-2019, 09:13 AM
mahunt's Avatar
Date registered: Feb 2008
Vehicle: 1997 SL600 Brilliant Silver Sport with grey/dark metal interior, 234K miles
Quoted: 360 Post(s)
I'm not a big proponent of the blower setup after 4 refurbishings.
Whenever I need to service the blower/regulator when it fails, I always check the operation of the blower fan by itself with a 12V source and a visual inspection of the motor brushes. The Behr fans do have a long service life, but the brushes can wear out faster that the motors or bearings themselves. I also make sure the bearings are lubed before putting a used (used by me) fan back into service. At least I know the fan isn't the problem.
After 2 not long lived replacement aftermarket regulators, I've switched to older original regulators by getting the early (and easier to replace) non integrated regulator. The integrated (heatsink/regulator) parts don't seem to be as robust.
mahunt is offline
post #4 of 16 (permalink) Old 04-02-2019, 10:50 PM Thread Starter
Quoted: 22 Post(s)
I suspect my new regulator was bad from the get go. I ended up ordering a new one, I don't know which brand it is but it should be OE quality and it was more expensive, around 150 euros (from a reputable MB parts dealer). I'll hopefully get it next week. I also ordered a new motor as I don't want to go back there anytime soon.
When I changed the regulator previously, I removed the old regulator by force, ground down the alignment tabs on the heat sink and tapped new holes for the new regulator. I trust I can keep using the old heat sink with the new regulator too. One thing I'll do differently this time is to use some Arctic Silver thermal paste and ditch whatever comes with the regulator.
ID:	2501300   Click image for larger version
juuso is offline
post #5 of 16 (permalink) Old 04-03-2019, 05:23 AM
mahunt's Avatar
Quoted: 360 Post(s)
Being formerly in IT, I too use Arctic Silver.
mahunt is offline
post #6 of 16 (permalink) Old 04-29-2019, 08:23 AM Thread Starter
Quoted: 22 Post(s)
New regulator, new motor, and still it happens. After an hour or more of driving yesterday, I noticed there was barely any air coming from any vent. The center vents felt cold though so some definitely was getting through.
I stopped the car and it sounded like the blower was running fine and it responded quickly to controls. After letting the car cool down a half an hour, everything worked again.
Now I'm thinking whether I might be dealing with a vacuum leak that causes some valve(s) to close when the car warms up. Or could the control unit itself fail like this?
I'm aware of the vacuum distributor block behind the firewall that tends to develop a crack. I replaced it just last summer.
juuso is offline
post #7 of 16 (permalink) Old 04-29-2019, 10:55 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '98 SL500, (2) '91 300SL, (2) '91 500SL, '00 S500
Quoted: 525 Post(s)
I don't believe any leak or valve failure can plausibly throttle the volume of air flowing into the cabin.
The control unit could be faulty. It's the very first thing you should have checked before touching the regulator or any other component.
By the brake booster I believe there is a terminal block with three wires going to the blower: (1) power, (2) ground, (3) control. With the blower on its highest speed setting measure the DC voltage between the middle wire (control) and the brown ground wire. You should measure at least 5 volts -- maybe considerably more.
bobterry99 is offline
post #8 of 16 (permalink) Old 04-29-2019, 11:04 AM Thread Starter
Quoted: 22 Post(s)
The thing is, it's a bit difficult to replicate this issue as I don't regularly drive the car for 1h+ and the problem doesn't occur before that. But yeah, I should have measured the voltage. I even have a multimeter with me all the time but didn't think about that. Anyway, it did sound like it was going at full speed, but it seemed something was preventing the flow of air.
juuso is offline
post #9 of 16 (permalink) Old 04-29-2019, 12:53 PM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1997 SL500- 40th Anniversary
Quoted: 482 Post(s)
I can relate a similar experience. After driving for around an hour, especially in mild temperatures wit a/c controls fully automatic, the amount of air would deminish to nearly none, even when I ran the fan to max manually. I discovered my evaporator was freezing up, thereby blocking airflow. After turning compressor off and giving it a bit of time, the ice would melt and the airflow would return to normal. I then put the system in diagnostic mode and discovered my evap temp sensor and heater plenum temp sensor both were faulty. Replaced each and cured the problem.
ot1 and Witek_M like this.
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #10 of 16 (permalink) Old 05-08-2019, 03:06 AM Thread Starter
Quoted: 22 Post(s)
Well that's an interesting finding! Probably not the same as mine though, because my problem also happened in the winter when the compressor wasn't running. I haven't done so in a while, but the last time I checked the sensors were giving plausible readings too.
Last week I ordered a refurbished AC control unit from eBay. This morning I took the car out for a longer drive with the new unit installed and the issue occurred again. At the end of the drive I removed the interior air filter and based on what I saw and heard, the blower was blasting at full speed like it was supposed to, so it's confirmed that something is just restricting the air flow.
Next I plan to do some vacuum diagnostics. Let's see if I find anything.
I'm getting a bit desperate here. In 2 weeks we're boarding a ship to Germany, and this is probably the only chance I will ever have to introduce this car to the Autobahn. If this issue doesn't get sorted out by then, well, it's goodbye to that dream.
juuso is offline
2001 S320 aircon blower very weak. crank1 W220 S-Class 0 11-19-2012 08:11 PM
2004 E420 4Matic AC Blower issue fixed stevenscottwest W220 S-Class 3 08-12-2012 05:52 PM
AC blower ??? thanh567 W210 E-Class 10 04-07-2011 02:00 PM
AC air blower fan is weak Abdullah2009 W126 S,SE,SEC,SEL,SD,SDL Class 7 09-02-2010 07:22 AM
A/C blower is weak... bruno787 W164 M-Class 10 11-27-2007 02:49 AM
