Airbag Steering changed and now SRS lamp ON - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-24-2019, 12:48 AM Thread Starter
Szabadi Kalman's Avatar
Date registered: Jul 2018
Vehicle: 1993 SL 500
Quoted: 15 Post(s)
Arrow Airbag Steering changed and now SRS lamp ON
Hi Guys !
I have changed the steering wheel to an aftermarket one (Wood Steering similar to Nardi) and right now the SRS light on the gauge cluster is on :/ [1993 SL500]
I heard I can make it disappear by using resistance, but I don't know how big resintance should I buy first to make it disappear ?
Thanks in advnace !
Szabadi Kalman is offline
post #2 of 6 (permalink) Old 03-24-2019, 02:22 AM
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
One could use the airbag emulator (designed for "testing purposes") https://www.ebay.com/itm/Car-SRS-Air...cAAOSwOMBbPX-m or a simple resistor https://www.ebay.com/itm/2X-BMW-MERC...wAAOSwB-1Y18Sy
Regards,
D
P.S. How about a picture of this new steering wheel in your car?
duh_vinci is offline
post #3 of 6 (permalink) Old 03-24-2019, 08:42 AM
FATHERTIME's Avatar
Date registered: Aug 2015
Vehicle: 94 SL320 98 SL500 99 SL600
Quoted: 235 Post(s)
Regards,
D
duh_vinci
I Want to swap the seat bottoms on my 98 SL500 but the child seat plug is an issue if not plugged in I get the SRS light do you know how to defeat this?
John;
FATHERTIME is offline
post #4 of 6 (permalink) Old 03-24-2019, 09:52 AM
duh_vinci's Avatar
Quoted: 252 Post(s)
Originally Posted by FATHERTIME View Post
duh_vinci
John,
Unfortunately, not having one these any either one of my R129 I can't say for sure. However, based on what I see under search for "R129 Occupancy Sensor" - it is 3 wire plug, so if I had to take a guess, the resistor based simple 2 wire plugins as above will not work. There Airbag360 is this device that "promises" to take care of the issue:
https://airbag360.com/mercedes-sl--c...pass-499-p.asp
Regards,
D
post #5 of 6 (permalink) Old 03-24-2019, 12:22 PM
Photodude's Avatar
Date registered: Apr 2013
Vehicle: 2004 E320, 2000 SL500
Quoted: 166 Post(s)
You can build one yourself or buy one of these
https://airbag360.com/sl-r129--1995-2001-116-c.asp
Andrew
Photodude is offline
post #6 of 6 (permalink) Old 03-24-2019, 04:55 PM
FATHERTIME's Avatar
Quoted: 235 Post(s)
Thanks guys I'll just buy this unit a lot easier than trying to figure out how to make it and blowing a module in the process
John;
