can't view this link.... - Page 3 - Mercedes-Benz Forum
post #21 of 28 (permalink) Old 04-22-2019, 09:45 AM
B G
Date registered: Apr 2019
Or maybe its due to amount of posts
B G is offline
post #22 of 28 (permalink) Old 04-22-2019, 09:45 AM
B G
Looks like I'm almost at enough I think it requires 10 posts or so
B G is offline
post #23 of 28 (permalink) Old 04-22-2019, 10:05 AM
B G
still no luck for me either
B G is offline
post #24 of 28 (permalink) Old 04-26-2019, 06:32 AM Thread Starter
Date registered: Jan 2009
Vehicle: 2001 SL600, 1995 SL500
Does anyone know if there are any "ACTIVE" moderators on this board...?
I have pm'd and e-mailed several times and get no response....
Still for some reason unbeknownst to me I can't view this link:
https://www.benzworld.org/forums/r12...l-exhaust.html
If anyone can help me view it I'd be grateful as I'm hoping to create a true dual exhaust on my SL500 as well....
If someone could just save the pictures and e-mail them to me that would be great too....
Thanks,
Brian
Last edited by RedLiner; 04-27-2019 at 12:28 AM. Reason: email address removed for security
02SL600SA is offline
post #25 of 28 (permalink) Old 04-26-2019, 12:31 PM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1997 SL500- 40th Anniversary
Quoted: 492 Post(s)
[quote=02SL600SA;17768240]Does anyone know if there are any "ACTIVE" moderators on this board...?
Thanks,
Brian
Yes, I do know there are "ACTIVE" moderators on this board, and one said he'd escalate your concern. Incidentally, the link you supply above is a dead-end.
I am unable to duplicate your issue, and do not have full access to your account. I suggest you allow Redliner to work his magic and be patient.
as for the pics... check your inbox.
Best Regards...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #26 of 28 (permalink) Old 04-27-2019, 12:27 AM
Administrator
RedLiner's Avatar
Date registered: Sep 2006
Vehicle: 1998 Pano SL500; 1993 SL500; 2005 ML270cdi
Quoted: 826 Post(s)
Thanks,
Brian
I sent you a PM yesterday with this link https://www.benzworld.org/forums/r12...-archived.html and you reported back that this link worked OK.
The link that you posted and could not open is corrupted. If you look at the links side by side you'll see a slight difference.
Anyway glad that you are now able to see the exhaust archive
I've also removed your email address from your original post and quoted replies, this is to prevent bots that harvest email addresses then bombard them with SPAM.
No trees were harmed creating this message, however some electrons were very inconvenienced.
RedLiner is offline
post #27 of 28 (permalink) Old 04-27-2019, 01:08 AM
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
Cheers!
I still can't see, its a dead link when I click on it... The one in this quote takes me to the page not found, and the link on the "1996 SL500 Custom Fabricated Dual Exhaust System" takes me to the page with "you do not have permission to access this page"
Regards,
D
duh_vinci is offline
post #28 of 28 (permalink) Old 04-27-2019, 03:21 AM
Administrator
RedLiner's Avatar
Quoted: 826 Post(s)
For some reason the link keeps getting corrupted.
I will now ask the site administrators to again look to see what the problem is.
I'll post back into this thread when I receive a response.
I'll test the link now, and again later with the results.
TEST: https://www.benzworld.org/forums/r12...-archived.html
EDIT: Link working just after posting
EDIT: Link still working after 24hrs.
EDIT: Link stiil working for me, can those affected see it?
LAMike240 likes this.
RedLiner is offline
HP Tuners Pro Feature Set Update HPTuners HP Tuners 1 12-03-2018 03:25 PM
2007 w221 S550 Sway Bar Link Replacement PWidge W221 S-Class 1 02-02-2018 06:02 AM
How to replace braking support link (bearing carrier) ball joints luckymike W126 S,SE,SEC,SEL,SD,SDL Class 11 10-18-2017 02:02 PM
rear view mirror adapter ikoiko W163 M-Class 4 12-06-2013 09:52 PM
Fiat pulls epic prank on Volkswagen rivals using Google Street View isthisdave Off-Topic 3 05-17-2012 12:29 AM
