Squeaking Top - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 03-13-2019, 10:17 PM Thread Starter
Photodude's Avatar
Date registered: Apr 2013
Vehicle: 2004 E320, 2000 SL500
Quoted: 164 Post(s)
Squeaking Top
My soft top has gotten little too squeaky when going up and down. I'm not sure what exactly is the source of the sound.
What's the best treatment to try to quiet the squeaking? Silicon spray maybe?
Andrew
Photodude is offline
post #2 of 10 (permalink) Old 03-14-2019, 11:09 PM
Date registered: Aug 2018
Vehicle: 1999 SL500
Location: Williamsburg, Virginia, United States of America
Quoted: 64 Post(s)
Mine too.. But it is still misaligned, so maybe that's it. I'd assume the sound is just the joints where it bends needing some WD-40 or something.
sully1218 is offline
post #3 of 10 (permalink) Old 03-15-2019, 11:26 PM Thread Starter
Photodude's Avatar
Quoted: 164 Post(s)
This squeaking sound was possibly coming from the springs… all is quiet now.
Andrew
post #4 of 10 (permalink) Old 03-16-2019, 07:52 AM
FATHERTIME's Avatar
Date registered: Aug 2015
Vehicle: 94 SL320 98 SL500 99 SL600
Quoted: 234 Post(s)
I think the springs make this noise too. I have tried sprays it seems to help a little but my next trick is going to be silicone grease on the spring anchors.
John;
FATHERTIME is online now
post #5 of 10 (permalink) Old 03-16-2019, 01:25 PM
wlb50's Avatar
Date registered: Mar 2013
Vehicle: 1996 SL500, 2000 E430
Quoted: 671 Post(s)
I sprayed silicone at the joints - wouldn't use a petroleum-based product like WD-40
duh_vinci likes this.
wlb50 is offline
post #6 of 10 (permalink) Old 03-16-2019, 02:12 PM
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
I would agree with not using any petroleum based product, specially near any rubber seals. I've been using Honda Shin-etsu Silicone Grease for years in all cars, affordable, last a long time and seem to work very well on all rubber seals https://www.amazon.com/Honda-Genuine...ag=googhydr-20
Regards,
D
duh_vinci is offline
post #7 of 10 (permalink) Old 03-16-2019, 08:07 PM Thread Starter
Photodude's Avatar
Quoted: 164 Post(s)
I wouldn't use WD-40 on any parts of the frame. As already mentioned it's bad on rubber. It would be ok on the springs I suppose but potential run-off could stain headliner, upholstery etc.
I used silicone spray on the joints then put the rug under the springs and sprayed them generously. After cycling top up and down couple of times squeaking was gone. For now at least.
Maybe thicker silicone grease would keep them quiet longer?
Andrew
post #8 of 10 (permalink) Old 03-17-2019, 11:16 AM
macysum's Avatar
Date registered: Feb 2011
Vehicle: '90 300SL | '13 CLS550 | '10 ML350 BlueTec | '08 E350
Quoted: 145 Post(s)
Mercedes makes a special lubricant for top squeaking. I can't find my supply of it or I'd post the p/n. I used it on my hardtop seals where they touch the body and it is effective.
_|_|_|_|_|_|_|_|_|_|_|_|_
'90 300SL-24 | '13 CLS550 | '10 ML350 Bluetec | '08 E350
Previous: '06 CLS500 | '07 ML350 | '89 560SEC | '85 300E
macysum is offline
post #9 of 10 (permalink) Old 03-17-2019, 12:17 PM
duh_vinci's Avatar
Quoted: 252 Post(s)
Yes, there is a "magical" lubricant from MB: Spezial Gleitmittel, A0009893660 $60 1.0 fl.oz little droplet bottle, specifically for anything squeaky, rubber or plastic related. Also a Silkonpaste A0009898451 and finally Gleitpaste (mostly for sunroof lube use) 0019894651, under $100
Regards,
D
post #10 of 10 (permalink) Old 03-17-2019, 11:15 PM Thread Starter
Photodude's Avatar
Quoted: 164 Post(s)
Thanks for posting this info and p/n
Andrew
Mercedes Benz R107 Hard And Soft Top Instructions isthisdave R/C107 SL/SLC Class 9 04-26-2015 03:53 PM
Some tips and tricks for convertible top cylinder rebuilds Arachnyd R170 SLK-Class 3 05-03-2012 01:42 PM
top codes grumpy old man R129 SL-Class 3 04-24-2012 12:21 PM
Watching top fuel dragsters talven Off-Topic 11 11-02-2009 01:39 PM
1992 Top Operation - I can't believe it happened to me! RoadKing R129 SL-Class 37 09-06-2008 10:08 AM
