On R129 is wheel change to 18" worth it ? - Page 2 - Mercedes-Benz Forum
LinkBack Thread Tools
Old 03-15-2019, 11:47 PM Thread Starter
Date registered: Mar 2019
Vehicle: Mercedes 1998 R129
Quoted: 4 Post(s)
Hi there, Its a 1998 model year SL 500 standard R129 Cabriolet made for the UK market.
Macabethiele is offline
Old 03-16-2019, 12:28 AM
FATHERTIME's Avatar
Date registered: Aug 2015
Vehicle: 94 SL320 98 SL500 99 SL600
Quoted: 235 Post(s)
My 98 SL500, lowered with 8.5 245/40/18 9.5 285/35/18. The 94 SL320 has 8. it's also lowered 245/45/17 all 4
Name:	98 SL500.jpg
ID:	2496644   Click image for larger version
Name:	94 SL320.jpg
duh_vinci likes this.
John;
FATHERTIME is online now
Old 03-16-2019, 01:57 AM Thread Starter
Quoted: 4 Post(s)
Is that Tormaline ? What ET offsett have you on the 18" rims ?
Old 03-16-2019, 02:28 AM Thread Starter
Quoted: 4 Post(s)
Our R129 on existing 17" wheels
Not sure if photo link will work.
Old 03-16-2019, 03:04 AM Thread Starter
Quoted: 4 Post(s)
Wink R129 Photo on 17" wheels
Hope this upload works taken after I had a new hood fitted !
Name:	new hood 004.jpg
Old 03-16-2019, 07:32 AM
FATHERTIME's Avatar
Quoted: 235 Post(s)
They are RONAL 30/33 10mm spacer in rear.
John;
Old 03-16-2019, 11:04 AM Thread Starter
Quoted: 4 Post(s)
Thanks for the reply FATHERTIME,
If I understand you right you have 30 mm offset at the front & 33 mm at rear plus 10 mm spacer for the rear.
You have no body fouling issues at the front with this set up & have not rolled the front fenders.
Here in the UK I have been offered some wheels they are a Multi Spoke Design being 8.5J ET30 X 18", my reluctance to buy them is based on trying some genuine MB 18" wheels that were from a R230. They looked great but.......
The fronts were 8.5J ET30 x 18, the rears were 9.5J ET33 x 18 but I did not record the tyre sizes fitted to the wheels. The rears fitted fine without clearance issues but the fronts rubbed the front wings / fenders so I did not buy them. It might be that the tyres were an over wide profile at the front.
My current 17" wheels are genuine MB Ankaa from an E Class they are 8.5J ET38 x 17 with 15 mm spacers all round - no clearance issues.
Old 03-16-2019, 12:03 PM
FATHERTIME's Avatar
Quoted: 235 Post(s)
I have no issues with front rubbing with the 8.5 30ET and 245/40 tires Your ET38 with 15MM spacers puts your final ET at factory center line
Name:	front wheel_9644.JPG
John;
Old 03-16-2019, 02:03 PM
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
...The fronts were 8.5J ET30 x 18, the rears were 9.5J ET33 x 18 but I did not record the tyre sizes fitted to the wheels. The rears fitted fine without clearance issues but the fronts rubbed the front wings / fenders so I did not buy them. It might be that the tyres were an over wide profile at the front...
It had to be the tire size, had to be too wide, as with these 8.5J ET30 x 18 and proper sized tires (same as John mentioned), 245/40/18 you should have no rubbing issues...
All of my cars are lowered, both R129 included, both with 18" wheels, both using 245/40/18 in the front, one with ET32 and this one one with ET25:
20181230_162417 by Duh_Vinci, on Flickr
absolutely no rubbing anywhere, even with hard cornering.
Regards,
D
duh_vinci is offline
Old 03-16-2019, 02:46 PM Thread Starter
Quoted: 4 Post(s)
R129 & 18" wheels
Thanks for your replies everyone, the wheels I found were on the internet in the UK but in the south of England over a 100 miles away, I am looking to find a retailer a bit closer to home ideally within 15-20 miles.
W210 Wheel Information Check Codes W210 E-Class 44 12-08-2015 08:46 PM
R1Concepts Performance Brake Parts - BenzWorld Member Discount NEOKEN R129 SL-Class 133 07-17-2015 04:49 PM
FS:Brabus 3 Piece Monoblock IV 18" wheel set of 4 Fesen For Sale/Wanted/Trade/Giveaway 2 09-12-2012 09:42 AM
The R129 18" AMG wheel paint & restoration davidiot R129 SL-Class 55 02-27-2011 01:41 PM
98 e320 steering wheel upgrade Babushka W210 E-Class 1 03-01-2005 01:58 AM
