M113 intake manifold job - Mercedes-Benz Forum
post #1 of 50 (permalink) Old 02-28-2019, 01:30 AM Thread Starter
Photodude's Avatar
Date registered: Apr 2013
Vehicle: 2004 E320, 2000 SL500, 1987 300TD
Quoted: 152 Post(s)
Never done this on M113, last time (6 years/ 35,000 miles ago) I paid for it but it looks like I may have to do it again. I'm thinking of doing this job myself this time.
Any thoughts and things I should be careful with while doing this?
Also, injector seals… what to use to lubricate them? I just replaced all injectors and couple of bottom seals may have some air leaks. I used (bicycle chain) Dry teflon lube, which is very similar to vaseline but not petroleum based. I'm not sure if it makes any difference…. lots of opinions out there… silicon, vaseline, teflon grease, wheel bearing grease etc.
I want to do this right because this engine, it seems, doesn't tolerate even slightest vacuum leaks.
Andrew
Photodude is online now
post #2 of 50 (permalink) Old 02-28-2019, 09:53 AM
AroundTheBenz's Avatar
Date registered: Oct 2015
Vehicle: 2001 SL500
Quoted: 127 Post(s)
Just curious: why do you need to remove the intake manifold ... vacuum leaks maybe?
I lubed my injector O-rings with a bit of synthetic engine oil ... not sure if that's what you're supposed to use but it works just fine.
Peter
AroundTheBenz is offline
post #3 of 50 (permalink) Old 02-28-2019, 11:45 AM Thread Starter
Photodude's Avatar
Quoted: 152 Post(s)
Hi Peter, I'm detecting small vacuum leaks but, with the spray test not easy to tell for sure if it's injectors or manifold gasket or possibly both.
Maybe I need to build one of those cheap smoke machines before I remove intake manifold.
Andrew
post #4 of 50 (permalink) Old 02-28-2019, 11:49 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '98 SL500, (2) '91 300SL, (2) '91 500SL, '00 S500
Quoted: 511 Post(s)
I've never heard of an "intake manifold job", Andrew. Seems unnecessary to me.
The engine management computer compensates for vacuum leaks. If yours fails to, then I would address that problem.
wlb50 and Smackrattle like this.
bobterry99 is offline
post #5 of 50 (permalink) Old 02-28-2019, 11:57 AM Thread Starter
Photodude's Avatar
Quoted: 152 Post(s)
It does but, when idle speed adaptations reach +1 ms CEL comes on with P0170 and P0173, which is what happens with my car.
Andrew
post #6 of 50 (permalink) Old 02-28-2019, 12:40 PM
Smackrattle's Avatar
Date registered: Nov 2005
Vehicle: vintage
Quoted: 964 Post(s)
^ I've not heard this as a routine failure on M113. How many miles on your engine? The most usual nuisance is leaking valve guide seals and rear main seal.
wlb50 likes this.
"Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful" - Seneca
Smackrattle is offline
post #7 of 50 (permalink) Old 02-28-2019, 01:35 PM Thread Starter
Photodude's Avatar
Quoted: 152 Post(s)
104,000 miles.
I'm not saying this is routine failure but, I've already had manifold gaskets replaced by the shop… who knows if they used genuine or after market, did they set them properly?
I already had to re torque them (slightly above 20 Nm) because they were causing idle adaptations near the +1 ms limit and CEL on and off. It helped for a while but, I'm back there again with CEL.
Andrew
post #8 of 50 (permalink) Old 02-28-2019, 01:50 PM
Vehicle: vintage
Quoted: 964 Post(s)
^ Thanks for the headsup. Mine's got about 102k - and it's been remarkably reliable, and a pleasure. As I mentioned, a bit of oil bypassing the valve stem seals, but it doesn't notice on start-up or when driving. Just asks for a litre after about 1200/1500 miles, earlier if I've been red-lining it a lot. I'm actually quite happy with a bit of consumption - stretches out my oil change intervals a bit!
post #9 of 50 (permalink) Old 02-28-2019, 05:07 PM
Quoted: 511 Post(s)
I'm not a Mercedes tech who sees this issue on a weekly basis, so what I have to offer here is purely speculation.
Those codes indicate the injection has exceeded it's ability to add or subtract up to 24% (25?) fuel. It's intuitive to me that if vacuum is leaking it has to be fairly (improbably?) massive. Another possibility, I believe, is a faulty air mass sensor under-reporting the amount of air entering the engine.
I would attach a vacuum gauge to the intake manifold. If there are major leaks, then this will be readily apparent.
post #10 of 50 (permalink) Old 02-28-2019, 07:13 PM Thread Starter
Photodude's Avatar
Quoted: 152 Post(s)
Hi Bob,
Thanks for trying to help, those mercedes techs… I'm not too sure who they're trying to help.
Here's what I've done so far, checked fuel pressure (58-60 psi), changed fuel filter just to be sure (it's been there 6 years/30,000 miles).
Connected SDS to check live data: MAP = 313-324 mbar, connected vacuum gauge to make sure MAP sensor is accurate, vacuum 20 in/ 50 cm. Normal IMO. Air mass fluctuates 8-12 kg/h I think it should be at 16 kg/h at idle. Idle speed adaptation at max (+1 ms) or above.
That to me looked like bad MAF sensor so I replaced it.
Not much have changed so I took it to the shop. They charged me $220 to reset adaptations and said nothing wrong with my MAF. I drove away and CEL came on the same day. Went back, they loaned me another MAF for couple of days… nothing changed. They want the car for couple of days… something else is going on. I took my MAF and see you later… I'm not paying another $200-300 just to find out.
Now, I'm detecting some vacuum leaks with the spray, maybe injectors maybe manifold gasket or possibly both, hard to tell this way… nothing massive.
Could minor vacuum leak possibly drive Air mass reading down?
Andrew
ID:	2492788   Click image for larger version
ID:	2492790   Click image for larger version
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
FATHERTIME
Intake Manifold Removal Mercedes-Benz Noob W126 S,SE,SEC,SEL,SD,SDL Class 6 09-15-2016 01:55 AM
BROKEN hose line y22/6b resonance intake manifold switchover valve NAJLEPSI C215 CL-Class 1 11-08-2011 12:44 PM
Diagnostic help needed long post fatbillybob W163 M-Class 10 12-04-2008 04:56 AM
Intake Manifold gasket and P0455 error meanknightgreen W140 S-Class 1 10-23-2008 07:11 AM
EGR Delete - Intake manifold cbjukraine W123 E,CE,D,CD,TD,TE Class 2 09-27-2006 08:25 AM
