SL500 Oil Change - Page 4 - Mercedes-Benz Forum
post #31 of 39 (permalink) Old 02-19-2019, 02:52 PM
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
Originally Posted by AroundTheBenz View Post
The M113 oil filter is at the top front left of the engine, so is removed from above. Isn't the M119 oil filter on the front right side down by the exhaust manifold, and the filter also removed from above ??
Indeed you are right, and yes, M119 is also a "top insertion" cartridge.
Regards,
D
duh_vinci is offline
post #32 of 39 (permalink) Old 02-20-2019, 03:19 AM
ceta4zng's Avatar
Date registered: Sep 2014
Vehicle: 2002 SL500 Silver Arrow
Quoted: 156 Post(s)
The top mounted filter cartridge is the reason I will switch over to the extraction-from-above method. My wife's SUV is the same way, meaning I can do at least two of my 'fleet' without removing undershrouds and crawling around on the ground. Seen my share of cross-threaded drain plugs and oil pans. Eliminating the need to mess with the plug is a good thing.
ceta4zng is offline
post #33 of 39 (permalink) Old 02-20-2019, 10:36 AM
Date registered: Mar 2007
Vehicle: 2000 SL320, 2001 CLK320
Quoted: 366 Post(s)
Advantage of doing it from underneath is one can check for any other problems down there, unless you changing every 6 months
rorypff is offline
post #34 of 39 (permalink) Old 02-20-2019, 02:16 PM
wlb50's Avatar
Date registered: Mar 2013
Vehicle: 1996 SL500, 2000 E430
Quoted: 671 Post(s)
Originally Posted by Ears View Post
but Iím pretty sure you canít remove the oil filter without removing the undershield.
Facing the engine, yours is on the top left side and is a cartridge type.
wlb50 is offline
post #35 of 39 (permalink) Old 02-21-2019, 04:23 AM
ceta4zng's Avatar
Quoted: 156 Post(s)
I only average 6,000 miles per year (8 mile commute and media test vehicles all year) - so I generally change oil by the calendar, not the mileage. Perhaps will put the car up in the air for the summer oil change and general inspection. Winter change will now be from above.
ceta4zng is offline
post #36 of 39 (permalink) Old 02-25-2019, 12:18 PM
Date registered: Jun 2015
Vehicle: '96 Mercedes S320, '99 Mercedes SL500
Quoted: 14 Post(s)
Hey Sully,
I use 10w-40 Mobil 1 synthetic and I'm in the northeast. Maybe someone else has more experience, but I think that 10w-40 is great for these cars in the summer, especially if you drive it hard. In the winter, I'm not sure if I should be using this!
Merc96 is offline
post #37 of 39 (permalink) Old 03-22-2019, 04:31 PM Thread Starter
Date registered: Aug 2018
Vehicle: 1999 SL500
Location: Williamsburg, Virginia, United States of America
Quoted: 63 Post(s)
I would just like to update this post and say that 5w-30 was recommended according to autozone
Merc96 likes this.
sully1218 is offline
post #38 of 39 (permalink) Old 03-22-2019, 05:32 PM
duh_vinci's Avatar
Quoted: 252 Post(s)
Yeah, autozone... MB factory oil 0w40 or 5W40... https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
Photodude likes this.
post #39 of 39 (permalink) Old 03-22-2019, 05:35 PM Thread Starter
Vehicle: 1999 SL500
Quoted: 63 Post(s)
That's just their own brand of oil. The Mobil 1 oil I got that was 5w30 is also on that sheet.
Oil Change '94 E320 LogicalPosition W124 E,CE,D,TD Class 21 12-18-2017 06:48 AM
Hidden Menace in the Gulf of Mexico Oil Spill's Real Threat Lies Beneath the Surface Teutone Off-Topic 11 06-10-2010 11:05 AM
Interesting article about how oil additives = snake oil chriswufgator R129 SL-Class 2 03-30-2008 12:13 PM
Oil change deathrattle Off-Topic 7 04-17-2006 09:32 PM
