SL500 Oil Change - Page 3 - Mercedes-Benz Forum
post #21 of 39 (permalink) Old 02-12-2019, 01:43 PM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 749 Post(s)
Yes, you can do it the old way, jack up the car and remove the bottom shield to access the drain plug etc.
RKH is offline
post #22 of 39 (permalink) Old 02-12-2019, 02:51 PM
robm.UK's Avatar
Date registered: Jun 2009
Vehicle: R129 500 SL 1991
Quoted: 292 Post(s)
Originally Posted by Photodude View Post
...so we can only speculate who the supplier is these days...
I speculate itís Petronas. .
robm.UK is offline
post #23 of 39 (permalink) Old 02-12-2019, 03:47 PM
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
I use the very same one, great capacity, just works! And yes, one could probably wear a tux for sure! Just clean and simple task, under the the car for oil change? Not any longer, love this thing! https://www.tooltopia.com/mityvac-7201.aspx
Regards,
D
duh_vinci is online now
post #24 of 39 (permalink) Old 02-15-2019, 06:39 PM
Don 300CE's Avatar
Date registered: Sep 2002
Vehicle: 1999 SL500, 2009 E350S 4Matic, 1992 300CE (sold)
Don 300CE
1999 SL500
1992 300CE - Now gone from my life ;-(
2009 E350 Wagon
Don 300CE is offline
post #25 of 39 (permalink) Old 02-17-2019, 09:07 AM
Vehicle: 78 300CD 79 300TD 84 300SD 84 300SD#2 88 300SEL 91 560SEC 84 560SEC 95 SL600 99 E300td 99 ML320
Quoted: 11 Post(s)
On the subject of oil suckers... You can make one for a coupla $$, get a tank of some kind (I had an old plastic gas can I used to use but an AC guy gave me an empty metal refrigerant tank), drill one hole for a hose barb fitting and another hole for a shop vac hose (like the 1.25" hoses) away from the barb hole. Get some plastic tubing that will fit in the oil dipstick tube (either that will go all the way down or fit tightly at the top) and put that on the hose barb. Put your shop vac in the big hole, the hose in the dipstick tube, get a beer, and turn on your shop vac. A few minutes later you have an empty engine, a beer in yo belly, and it's all clean.
Photodude and FATHERTIME like this.
RichDiesel is offline
post #26 of 39 (permalink) Old 02-17-2019, 11:59 PM
wlb50's Avatar
Date registered: Mar 2013
Vehicle: 1996 SL500, 2000 E430
Quoted: 679 Post(s)
I have used this for 20 years...
wlb50 is offline
post #27 of 39 (permalink) Old 02-18-2019, 09:43 AM
AroundTheBenz's Avatar
Date registered: Oct 2015
Vehicle: 2001 SL500
Quoted: 130 Post(s)
All that said, I still prefer to drive up on my ramps, slide under the car, drop the cover (only 4 screws) and let the oil whoosh out through the drain plug hole into a bucket. This gives me a chance to check the underside of the engine for any signs of leaks or trouble.
AroundTheBenz is online now
post #28 of 39 (permalink) Old 02-19-2019, 01:57 AM
wlb50's Avatar
Quoted: 679 Post(s)
You shouldn't have to remove the bottom shield, at last on my '96 they left a big enough opening. Still draining is not my preferred method.
wlb50 is offline
post #29 of 39 (permalink) Old 02-19-2019, 12:02 PM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1997 SL500- 40th Anniversary
Quoted: 514 Post(s)
but I’m pretty sure you can’t remove the oil filter without removing the undershield.
Best Regards...
RM Smith
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #30 of 39 (permalink) Old 02-19-2019, 02:35 PM
Vehicle: 2001 SL500
Quoted: 130 Post(s)
Originally Posted by Ears View Post
but Iím pretty sure you canít remove the oil filter without removing the undershield.
The M113 oil filter is at the top front left of the engine, so is removed from above. Isn't the M119 oil filter on the front right side down by the exhaust manifold, and the filter also removed from above ??
duh_vinci likes this.
Oil Change '94 E320 LogicalPosition W124 E,CE,D,TD Class 21 12-18-2017 06:48 AM
Hidden Menace in the Gulf of Mexico Oil Spill's Real Threat Lies Beneath the Surface Teutone Off-Topic 11 06-10-2010 11:05 AM
Interesting article about how oil additives = snake oil chriswufgator R129 SL-Class 2 03-30-2008 12:13 PM
Oil change deathrattle Off-Topic 7 04-17-2006 09:32 PM
