1995 SL500 Sound System overhaul - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 03-18-2019, 12:50 PM
FATHERTIME's Avatar
Date registered: Aug 2015
Vehicle: 94 SL320 98 SL500 99 SL600
Quoted: 218 Post(s)
Originally Posted by duh_vinci View Post
Yep, that's where Focal tweeters will go - indeed makes a big difference. Sound stage transforms! Already removed the stock phone speakers, temporary old pair of old Boston tweeters in it, powered by the new head unit.
Regards,
D
So you're not running the tweeters off the amp and connecting direct to the head unit? Will you run all the wiring through the raceway on the drivers side sill?
John;
FATHERTIME is offline
post #12 of 14 (permalink) Old 03-18-2019, 04:05 PM Thread Starter
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 249 Post(s)
Originally Posted by lowesguy View Post
Someone gave me a complete rear shelf assembly, so cannibalized it with bass speaker, ported it ,recovered, put a 3 or 500watt amp in trunk at side, have a bass control knob at console slide compartment, works great, with top down outside noise cuts the sound in half.
A better head unit would be nice, door and dash speakers are original and work fine.
Yes, thats the biggest hurdle to overcome with convertibles for sure!
Originally Posted by ceta4zng View Post
I'm still recommending the Pioneer MVH-series (I bought the MVH-S512BS) or SPH-10bt over the Kenwood. I had the KDC-mp562bt that sounded terrible in the stock system compared to the Pioneer I replaced it with. Then the smart sync app basically lets you use your phone to control the headunit - including navigation. So for road tripping, mount your phone, press the nav button and your preferred app comes up (waze, maps, etc). And 200,000 color choices for the display and buttons let you match perfectly to the interior.
I'm sure your custom install will sound fine with the Kenwood - but the Pioneer app and the plug-and-play of the Pioneer was worth the $100 spend.
When I purchased this Kenwood KMM-BT322U, the Pioneer MVH-S512BS was not available yet. I don't really need many features, I do like the simple design with symmetrical layout, 6ch preout is a must, DTA is a must, adjustable illumination is a must and BT is a must. Kenwood fell right in. With that said, and now I've had it for over 6 months - NOT a unit I would recommend. Integration with Windows phone or Android phones is very very unstable. It does however, control Spotify and Pandora perfectly well, DTA is perfect. Night illumination is spot on with Orange1 and fairly easy to see during the day.
P1010913 by Duh_Vinci, on Flickr
Now that these Pioneers are out, flat, simple layout, has all the features I needed and more, If I had to do it allover again, I would deviate from Kenwood for sure (would be the first time in many many years)
Those Focal tweeters will indeed be running of that 5-channel amp via 2 way supplied x-over, other 2 channels to rear 6x9 and last mono channel to 10" sub. My current tweeters (temporary old Bostons) are running off the head unit only, and small mono amp is powering the Acoustimass bass driver in the factory Bose enclosure, basically same speaker as factory, just 4 ohm instead of factory 2 ohm (if I remember correctly). I just didn't want to stress the little amp
IMG_20180609_182936 by Duh_Vinci, on Flickr
Identical drivers
IMG_20180609_182531 by Duh_Vinci, on Flickr
And analog bass control for now in this compartment (but will be relocated to the center console ashtray
IMG_20180616_165737 by Duh_Vinci, on Flickr
Regards,
D
duh_vinci is offline
post #13 of 14 (permalink) Old 03-23-2019, 01:44 PM Thread Starter
duh_vinci's Avatar
Quoted: 249 Post(s)
A little progress today, rear speakers are fitted!
Under mounted them
20190323_152433 by Duh_Vinci, on Flickr
Covered the grill inserts with grill cloth
20190323_150616 by Duh_Vinci, on Flickr
20190323_150550 by Duh_Vinci, on Flickr
I had to modify some of the mounting points of these custom grills, but well worth it. Low profile, all metal, very sturdy, painted the outer frame mate black
20190323_153731 by Duh_Vinci, on Flickr
Overall, very happy with the look and fit
20190323_155113 by Duh_Vinci, on Flickr
Regards,
D
Ears and FATHERTIME like this.
post #14 of 14 (permalink) Old 03-27-2019, 07:08 AM
Date registered: Aug 2018
Vehicle: 1999 SL500
Location: Williamsburg, Virginia, United States of America
Quoted: 63 Post(s)
Do we know the largest size speaker that will fit in the rear? Like a small two-way?
Identical drivers
Regards,
D
sully1218 is offline
post #15 of 14 (permalink) Old 03-27-2019, 01:59 PM Thread Starter
duh_vinci's Avatar
Quoted: 249 Post(s)
By my measurements under 2.8" in overall diameter. On SL320 I used Dayton Audio Reference drivers throughout, rears are RS75-4, these are 2.83" overall diameter and you can see here that it is "max" and that is with trimming frame few millimeters. Mounting depth is very VERY restrictive as well https://www.benzworld.org/forums/r12...l#post15560817
To make these Dayton driver's a true 2-way rear fill, I've added a pair of tweeters at the corners just above the factory drivers and both covered both in matching grill cloth
Regards,
D
