Infra Red Remote System (Yes, I searched!) - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 11-22-2018, 05:40 PM Thread Starter
WordMan's Avatar
Date registered: Oct 2018
Vehicle: 1997 SL320
I have searched and read a good dozen posts on the IR remotes, but I can't seem to find an answer to my particular problem.
1997 Sl320
Single button infrared remote
I have two remotes that work well, but only at night. In the daytime, even in the carport, no joy. I can get them to work if I hold the remote nearly against the sensor with my hand around the remote to block all light. All three sensor points work in the dark, but not with the sun up.
Thoughts?
The right to self defense is fundamental to a free state. If, by dictate of the state, it is unlawful to defend your own person, you are not a citizen of a state, nor even a subject a monarch, but the property of feudal lord.
WordMan is offline
post #2 of 14 (permalink) Old 11-22-2018, 07:14 PM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 749 Post(s)
Have you check the battery in the remote ? and clean the lens (of the remote and the receiver).
RKH is offline
post #3 of 14 (permalink) Old 11-22-2018, 07:26 PM Thread Starter
WordMan's Avatar
Vehicle: 1997 SL320
Both remotes have new batteries. I polished one of the receiver lenses, but it made no difference. The lenses on the remotes seem clear.
WordMan is offline
post #4 of 14 (permalink) Old 11-22-2018, 08:00 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 97 E-420 (180K miles), 97 SL500, (93K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax(55K)
Quoted: 579 Post(s)
in my case I had similar symptoms even with brand new remote batteries but ONLY with the trunk IR sensor. sensor was on it's way out and replacing the sensor solved the problem.
In your case, not working on all 3 sensors, wouldn't immediately have me believe sensors are the issue. and since it is with both remotes, doesn't sound like remotes. Not sure what that leaves for possibilities.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #5 of 14 (permalink) Old 11-23-2018, 12:10 AM
R129FE's Avatar
Date registered: Feb 2018
Vehicle: 2000 SL R129 Final Edition brillant black
Quoted: 41 Post(s)
I guess with the 97 the sensor is rather underneath the inner rearview mirror than in the doors or trunk, perhaps it needs some cleaning.
R129FE is offline
post #6 of 14 (permalink) Old 11-23-2018, 03:54 AM Thread Starter
WordMan's Avatar
Vehicle: 1997 SL320
Mine are in the doors and trunk lid.
WordMan is offline
post #7 of 14 (permalink) Old 11-23-2018, 04:03 AM Thread Starter
WordMan's Avatar
Vehicle: 1997 SL320
Well, you've answered one of my thoughts/questions, anyway. I was thinking perhaps the sensors were somehow daisy-chained and thus a single bad one might affect all the others.
The next question was, could all three sensors be bad. The car did spend a fair amount of its life in Florida (and the Florida sun), but I wouldn't think the sensors would degrade from sun exposure, rather I figured they would "go bad" (i.e. not work or work intermittently).
So the only common part is the brain, yes?
Which then leads me to the next question: as the brain appears to be discontinued, I'll need to buy one used (I see several on Ebay, so that's not a problem), do I need to match my part number exactly, or are they all interchangeable?
WordMan is offline
post #8 of 14 (permalink) Old 11-23-2018, 08:32 AM
e-420's Avatar
Quoted: 579 Post(s)
97 doesn't have a mirror sensor, just sensors in each door and trunk.
e-420 is offline
post #9 of 14 (permalink) Old 11-25-2018, 06:33 AM Thread Starter
WordMan's Avatar
Vehicle: 1997 SL320
Well, since it's the thing that's common to all three sensors, I ordered a used module. We'll see if it works...
WordMan is offline
post #10 of 14 (permalink) Old 11-25-2018, 04:33 PM
robm.UK's Avatar
Date registered: Jun 2009
Vehicle: R129 500 SL 1991
Quoted: 292 Post(s)
I had same problem with a '92 500SL. Read all the posts. Tried most things people recommended, including replacing fuses. No luck. I ended up solving the problem completely by accident while trying to sort out another problem.
Engine had an intermittent hesitation at high revs. Narrowed it down to MAS module. I did a blanket solder on the MAS module pcb, and... this is the relevant bit - at same time I unplugged every module in the engine bay and cleaned the contacts with electrical spray cleaner. While I was at it, I did same with the modules in the trunk. I also replaced the OVP.
[Edit - I also recall that I cleaned the earth straps to]
Hesitation was fixed, but to my surprise so too was the infra-red central locking. This was 2 years ago, and infra-red still works like new. Full daylight 5m away.
My best guess is that the problem with old infra-red locking systems is due to a build up of electrical resistance in the wiring/circuit over time, which could explain why cleaning the contacts and changing the OVP worked.
My best guess is that any change in the current to the IR sensors (by a few hundred milliamps) affects the sensitivity of the IR sensors to different wavelengths of light. The build up of resistance reduces the current in the IR circuit, which changes the sensivity of the IR sensors so that they no longer see the IR, or they have a reduced sensitivity to IR light.
WordMan likes this.
robm.UK is online now
