SRS warning light ON - Page 2 - Mercedes-Benz Forum
post #11 of 21 (permalink) Old 09-21-2018, 05:19 PM Thread Starter
Photodude's Avatar
Date registered: Apr 2013
Vehicle: 2004 E320, 2000 SL500
Quoted: 169 Post(s)
OK. I didn't realize how easy it is to take this out…
Now, I've never done upholstery work so how do I get the leather off. Is the sensor pad a separate part or integrated into seat cushion?
Also are driver and passenger seats identical? I wouldn't mind swapping them.
Photodude is offline
post #12 of 21 (permalink) Old 09-21-2018, 07:53 PM
Date registered: Jun 2007
Vehicle: 89 300E (210K), 90 560SEL (113K), 93 300E 3.2
Quoted: 2 Post(s)
MY 99 sl500, SRS light on , Air bag light off is on. Check all wirings but all good so the problem is sensor. You can try to dectivate by the switch on the side of the passenger seat (didn't help on mine). Can't find the part on line and have no time to go to dealer end up with order emulator from Ireland. all lights is off. I don't have kid and won't put kid in car anyways. For me, If you don't put kid in the front seat, this is the cheaper and easier way than replace the sensor.
ID:	2455427   Click image for larger version
ID:	2455429   Click image for larger version
sorayuth is offline
post #13 of 21 (permalink) Old 09-21-2018, 08:49 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 97 E-420 (180K miles), 97 SL500, (93K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax(55K)
Quoted: 579 Post(s)
no seats are not identical, and the drivers and passenger side don't have the same air bag sensor. IIRC the drivers side may not even have one.
try plugging the yellow plug back in and see if the SRS failure goes away. Had that issue on mine once, plug had somehow come loose.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #14 of 21 (permalink) Old 09-21-2018, 10:04 PM Thread Starter
Photodude's Avatar
Quoted: 169 Post(s)
I didn't mean identical as far as sensors, Gee I hope they didn't put child sensor on driver side…
I should have said symmetrical… so they would fit on the opposite side. If I were to replace sensor I could fit it on Driver seat and put it on passenger side. Or if I were to use emulator I could just swap them without any additional work.
Just a thought because passenger seat is in better condition.
post #15 of 21 (permalink) Old 09-22-2018, 02:56 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
Quoted: 597 Post(s)
Yes, except for later models incorporating the air bag sensor in the passenger side.
Originally Posted by sorayuth View Post
...end up with order emulator from Ireland.
That emulator likely consists simply of two or three resistors and a diode. Together they all cost less than $1.
The diagnostic manual essentially explains how to bypass the sensor here: STAR TekInfo (bottom of page). Across two sensor wires you connect a "1N4007" diode in series with a 300-ohm resistor, and in parallel with that you place either a 30K-ohm or smaller resistor to show the controller the seat is occupied, or a 75K-ohm or larger resistor to show it is not.
bobterry99 is offline
post #16 of 21 (permalink) Old 09-22-2018, 06:29 AM
ka707's Avatar
Date registered: Apr 2009
Vehicle: A 96 Pano roof SL500, 95 E280, 90 E300-24 coupe, bmw coupe M3, bmw x5
Quoted: 21 Post(s)
Send a message via Skype™ to ka707
I might be able to help here, I had the same problem and fixed it easily, it came down to a broken wire. I'll come back with a longer description of the problem
ka707 is offline
post #17 of 21 (permalink) Old 09-22-2018, 06:36 AM
ka707's Avatar
Quoted: 21 Post(s)
This is what the sensor looks like. Note I pulled the squab out, then the leather cover off the squab, then the sponge seating off the sensor. I have a spare sensor which I bought and in the end did not need it! Before you do all of that check out the condition of the wire leading from the sensor to the plug under the seat. you can see it here in the pic at the very bottom, a grey wire running away from the seat.
Now, when the seat is in place, this wire runs through the metal frame that holds the seat squab in place. The wire flexs ever so slightly as the seat is used. One of the wires had broken inside the grey insulation at the point where it crosses the hole in the metal frame. I found this out after I pulled the whole seat apart unnecessarily. Easy to check continuity with a meter! Hope this helps. COme back with questions if you need to
rgds
k
Name:	passanger sensor of seat squab.jpg
ka707 is offline
post #18 of 21 (permalink) Old 09-22-2018, 12:16 PM Thread Starter
Photodude's Avatar
Quoted: 169 Post(s)
Something is definitely wrong with the sensor or wiring, doesn't matter really. I like the emulator solution, cheap and easy. This sensor would probably be problematic even if replaced and I don't really need it.
I'd still be curious how to remove leather from the seats, just in case I wanted to replace cushion pads. What's the trick to get it off?
post #19 of 21 (permalink) Old 09-22-2018, 03:25 PM
duh_vinci's Avatar
Date registered: Feb 2015
Vehicle: 1995 SL320, 1995 SL500 ("Red Devil " project), 1998 C280, 2004 E500 4matic
Quoted: 252 Post(s)
...I'd still be curious how to remove leather from the seats, just in case I wanted to replace cushion pads. What's the trick to get it off?
I've replaced the skin on the bottom of my SL500, it's kinda difficult to explain, but basically, there is a metal channel all around the perimeter of the bottom of the seat. Skins have fiber strips sown in that tucks in those metal channels. To remove, the seat bottom should be in upside down position as you have in the picture, apply firm and even pressure (knee) to the middle of the metal frame, that relieves the tension of the skin and carefully, start pulling the fiber strip from the channel carefully, starting at the back.
Not sure if this helps, but here is someone's blog (early model, but the principle is the same), you can see the fiber strip and the channel fittings R129 500sl Restoration: Reupholstering the 500SL
Regards,
D
Photodude likes this.
duh_vinci is offline
post #20 of 21 (permalink) Old 09-22-2018, 04:15 PM Thread Starter
Photodude's Avatar
Quoted: 169 Post(s)
Of course this helps, Thanks. I had no idea where to start with this.
I actually just installed the seats back, I didn't even realize how much better (firmer) passenger seat was until just now that it is on MY side. Little cleaner too.
At some point though I might replace both cushion pads. So it's good to know.
