r 129 roof issue - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 05-09-2016, 10:16 AM Thread Starter
Date registered: May 2016
Vehicle: 1990 r129 1988 w123
r 129 roof issue
1990 r 129 300-sl-24
the roof will not go up properly
gets to the highest point (about halfway) and just stops.
Been looking around the car today, nothing out of the ordinary except the roof switch stays illuminated when I lock it all down and the car bleeps when I drive it
The oil was dirty so I changed that but that made no difference.
Any ideas ?
thx colin
colin129 is offline
post #2 of 11 (permalink) Old 05-09-2016, 10:40 AM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 743 Post(s)
When you say change the 'oil', I assume you mean the hydraulic fluid. How was the level in the tank before you change it ? If it was below normal you may have a leak in your system.
RKH is offline
post #3 of 11 (permalink) Old 05-09-2016, 10:49 AM
R129 HTT Founder Member
Pete S's Avatar
Date registered: Sep 2012
Vehicle: 040 96' SL500, 368 08' E550 4Matic, 775 08' R350 4Matic, 9147 13' Sprinter 2500
Quoted: 962 Post(s)
What RKH asked and you can also try to close it manually and lock everything in place and try to cycle it too see if that cures the problem.
sleauxdaddy and isthenew like this.
Mercedes aren't for people who want to have one, it's for people who can have one.
Pete S is offline
post #4 of 11 (permalink) Old 05-09-2016, 04:21 PM
isthenew's Avatar
Date registered: Jan 2014
Vehicle: 1989 300SE 232k miles
Quoted: 219 Post(s)
Stopping 1/2 way up could be a problem w/power. Is the car running? Because if not, you may not have enough electrical juice.
And stopping 1/2 way up is where the pressure sensor changes pressure to slow the top when lowing toward the windshield. I understand that's what the hydraulic pressure thingie up on the front windshield is for.
isthenew is offline
post #5 of 11 (permalink) Old 05-09-2016, 11:59 PM Thread Starter
r129 issue
I changed the oil because it was so dirty. The level was between the two marks.
The car is running so not power I think.
I need to look at the pressure change, maybe that could be the issue
thx
colin129 is offline
post #6 of 11 (permalink) Old 05-10-2016, 04:20 AM
alpac's Avatar
Date registered: Aug 2013
Vehicle: 1992 500SL, 1999 CLK 320 conv, 2015 ML350, (2011 ML550 gone, C320 wagon gone, 2005 C240 gone)
Quoted: 92 Post(s)
What type of hydraulic fluid did you use? When the roof goes up and stops does it go back when you press the button in reverse? If yes try to do that up and down move several times to bleed and clean the circuit and while your engine is running. If your fluid was really dirty as you said it was it may have clogged and restricted your circuit not allowing enough pressure to be built. As you do that check if there is any trace of fluid leaking on the ground in front and back of rear tires. You may also have leaking cylinders. What is the history of the car? Has the roof ever worked since you own it? Your car is a 1990 model and if the cylinders have never been replaced I bet you have leaking cylinders. Cycling the roof as suggested willl make a leak obvious.
isthenew likes this.
alpac is offline
post #7 of 11 (permalink) Old 05-10-2016, 07:40 AM
Date registered: Jan 2008
Vehicle: SL 60 1998
Quoted: 34 Post(s)
Do not rely on the engine running to give you enough power, if the battery is old it still will not work properly, it is the amps not the voltage. I had this problem early last year. The solution was a new battery,problem solved.
fintonso and isthenew like this.
1998 SL 60
1991 SL 500 (sold)
nt-j is offline
post #8 of 11 (permalink) Old 05-10-2016, 09:37 AM
RKH
RKH's Avatar
Quoted: 743 Post(s)
thx
Level is between the 2 marks, so there is not 'external' leak (unless it has been topped up just before you bought the car).
If 'Dirty oil' as in blackish color with residue at bottom of tank, that would indicate deteriorating seals. With no fluid loss, it could be internal leak between the 2 chambers which would result in pressure problem and that could explain your case of stopping at the peak.
rorypff and isthenew like this.
RKH is offline
post #9 of 11 (permalink) Old 05-11-2016, 01:38 AM
Richard F's Avatar
Date registered: Feb 2014
Vehicle: 1994 SL320
Quoted: 449 Post(s)
I'm surprised at this, I know the soft-top mech draws plenty of power, I usually leave the engine running because of this.
But I'd always thought that the alternator would produce enough current to power it.
Richard F is offline
post #10 of 11 (permalink) Old 05-11-2016, 05:29 AM
Vehicle: SL 60 1998
Quoted: 34 Post(s)
Richard,
That is what I thought, but accidentaly I was trying to close the roof and had the battery charger connected, it worked perfectly. Solution - new battery,no problems since.
Nigel
1998 SL 60
1991 SL 500 (sold)
nt-j is offline
