Vibration At Highway Speed - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-03-2015, 07:00 PM Thread Starter
Date registered: Oct 2014
Vehicle: 2000 SL500
Quoted: 18 Post(s)
When I drive at highway speeds, there seems to be a vibration in the seat. It used to be in the steering wheel, but I don't notice it there too much anymore.
I'm hoping the wheels just need balancing, but could it be flex discs or driveshaft balancing?
Any input would be great!
marko88 is offline
post #2 of 7 (permalink) Old 06-03-2015, 10:46 PM
Richard F's Avatar
Date registered: Feb 2014
Vehicle: 1994 SL320
Quoted: 449 Post(s)
Balance the wheels, check for buckles, check the tyres, check flex disc (this last one is important you don't want one failing)
If you think it's a wheel/tyre move front to back to see if the vibration moves.
Richard F is offline
post #3 of 7 (permalink) Old 06-04-2015, 05:30 AM
Date registered: Apr 2013
Don't forget Engine, Transmission and Final Drive mounts.
All need to be alligned and if not can cause viabration.
Peter
PeterW113 is offline
post #4 of 7 (permalink) Old 06-04-2015, 02:28 PM Thread Starter
Vehicle: 2000 SL500
Quoted: 18 Post(s)
I've booked the car in for engine mounts and trans. mount replacement and wheel balance. Also getting a new pinion seal and diff. fluid change.
marko88 is offline
post #5 of 7 (permalink) Old 06-05-2015, 02:20 PM
Sc00p's Avatar
Date registered: Oct 2007
Vehicle: 2002 SL500 Silver Arrow (Sold May 2019 after 11 1/2 years)
Quoted: 9 Post(s)
I started a thread with the identical heading about 6 years ago. I found the same issue, and balanced the tires 3 times, replaced a wheel I was told was bent (that probably wasn't) all with little effect. I have come to the conclusion that the vibration is just what these cars do. I don't feel it with the hard top on. I don't feel it with the soft top down. I do feel it with the soft top up. I honestly believe it's the design that results in vibrations at highway speeds - it has to have something to do with the aerodynamics. Of course, your experience might be different from mine.
SinSL likes this.
Cogito ergo Mercedes Benz...I think therefore I drive Mercedes Benz
Sc00p is offline
post #6 of 7 (permalink) Old 06-05-2015, 03:10 PM
Date registered: Jul 2013
Vehicle: 380SL, Jag F-type
Quoted: 300 Post(s)
I reached the same conclusion. If your car doesn't vibrate with the lid on, you can't fix this.
SinSL is offline
post #7 of 7 (permalink) Old 06-05-2015, 06:42 PM Thread Starter
Vehicle: 2000 SL500
Quoted: 18 Post(s)
Interesting. I suppose it's possible. Unfortunately I don't recall if it vibrates with the HT on. I guess I'll find out if the service will remedy things.
marko88 is offline
