1992 500SL Power Steering Replacement Procedure Needed - Page 3 - Mercedes-Benz Forum
post #21 of 27 (permalink) Old 06-06-2015, 12:08 PM
Date registered: Jan 2012
Vehicle: 2014 Merc G550, 97 Mercedes SL600, 09 Pontiac G8 GT, 03 Yamaha V-Star Classic, 91 Pont Firebird
Quoted: 5 Post(s)
Hi Phil,
I wrote you back through your email a few days ago letting you know I have the vickers pump break down (77) pages worth but needed your vin to make sure it is exactly like yours. The program I have involves every mercedes made for every country so inputting your vin ensures the correct procedure and part.
Kayrunner
kayrunner is offline
post #22 of 27 (permalink) Old 06-07-2015, 08:38 AM Thread Starter
Date registered: Jun 2007
Vehicle: 1992 500 SL
Kayrunner,
I never received your email, I just checked again unless I accidentally deleted it?
Anyway my VIN is WDBFA66E0NF061509 - 92 500SL
The pump breakdown would be really helpful if I can ever get this bracket off so, in addition and first I need the diagram of the pump and bracket to see if there are any hidden bolts possibly from behind or underneath the car. I've been hearing that there is a E12 bolt that can only be gotten from underneath but that was on a 97. I'm going to look for it tomorrow but I have to push the car out of the garage and put it on jack stands to look for it. so, the blow-out (I think that's what it's called) would be very helpful.
Thanks in advance.
Phil
[email protected]
Phil DeSimone is offline
post #23 of 27 (permalink) Old 06-07-2015, 01:08 PM
Quoted: 5 Post(s)
I answered also by email. Replying both ways so no more confusion. Ok so the documentation I have is the total pump breakdown, breakdown of its attachment, all tools involved and part numbers to reorder any broken or lost parts. I should have it over to you by late tonight. Thanks for the VIN.
Kayrunner
post #24 of 27 (permalink) Old 06-08-2015, 10:14 PM
Quoted: 5 Post(s)
Ok, sent by email the 77 pages in pdf form. Let me know if there is anything else you may need. Good luck with your repair!
Kayrunner
post #25 of 27 (permalink) Old 06-09-2015, 06:28 AM Thread Starter
Kayrunner,
I'm not getting your emails. The first or the second with the 77 page PDF.
Are you sending it to .net
Phil
[email protected]
Thanks
post #26 of 27 (permalink) Old 06-11-2015, 05:22 PM Thread Starter
OK, lets put this thing to bed.
First of all, I want to thank everyone that replied to my post. I learned something from each of you.
I never did get the bracket holding the pump and reservoir off. I did discover a 6mm Allen that looked like it may have held the bracket on from the back and gotten from under the car. I didn't have the right mixture of sockets and swivels to get it off so I said screw it and went to plan C. Trying to follow the Pelican Parts procedure, I realized that 4 bolts held the top of the pump unit on the base. My leak was coming from the main seal so, I just unbolted the top of the pump, carefully removed it and rebuilt the top half of the pump. I put the whole thing back together and so far, it's not leaking. I really wanted to change that 3 inch piece of hose under the reservoir but, I only had so much patience and had to give this technique a shot.
Thank you all for your help.
Phil
post #27 of 27 (permalink) Old 05-05-2019, 08:14 PM
Date registered: Aug 2011
Vehicle: 1991 500SL R129
Quoted: 4 Post(s)
Hi Kayrunner, I'm Keith. I was reading a post of yours regarding the dual pump from a while ago. I am about to remove mine as it has failed, no oil being pumped at all. I have a 1991 500SL, Vin WDB1290662F046617. I was reading that you have a 77 page pdf with diagrams of the pump, I wonder if I could trouble you and ask for a copy please. Regards...Keith
Keithdm is offline
