300sl hot start problem - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 06-24-2019, 10:36 PM
Christian Omloop's Avatar
Date registered: Jul 2018
Vehicle: SL 300 24V
Quoted: 6 Post(s)
Thnx again!
I’ll try to test csv this evening.
Christian Omloop is offline
post #12 of 15 (permalink) Old 06-25-2019, 10:55 AM
Vehicle: SL 300 24V
Quoted: 6 Post(s)
I was not able to remove the CSV, 3 injector lines and a tube of the ISV are in front of the second bolt. I’m going to remove the injectors and the CSV at once when the weather is bad.
I noticed that the ISV gets 12v as soon as you turn the key, even before you start the engine. Not sure if that is supposed to be like this.
post #13 of 15 (permalink) Old 06-25-2019, 04:22 PM
robm.UK's Avatar
Date registered: Jun 2009
Vehicle: R129 500 SL 1991
Quoted: 292 Post(s)
Originally Posted by Christian Omloop View Post
I was not able to remove the CSV, 3 injector lines and a tube of the ISV are in front of the second bolt. Iím going to remove the injectors and the CSV at once when the weather is bad.
Control module varies the current to ISV. Voltage is constant.
robm.UK is offline
post #14 of 15 (permalink) Old 06-25-2019, 10:05 PM
Vehicle: SL 300 24V
Quoted: 6 Post(s)
Makes sense :-) thnx!
I'll be back once I tested the injectors and CSV
post #15 of 15 (permalink) Old 07-06-2019, 09:57 AM
Vehicle: SL 300 24V
Quoted: 6 Post(s)
This afternoon I was about to test the injectors and CSV when I noticed a fuel smell after removing the Air Filter.
Pushing the sensor plate down increases the odor and I noticed that the inside of the housing was a little wet.
Is it mormal that there is a little bit of fuel in the housing?
The only thing that I can think of is that the plunger is leaking. Fuel distributor was refurbished and all the sealings were renewed.
1990 300SL Won't Start Cold CAPER5 General Mercedes-Benz 0 09-21-2009 04:58 PM
300sl hard to start ahats R129 SL-Class 3 07-09-2009 06:55 AM
1990 300sl Cold Start Problem CAPER5 General Mercedes-Benz 0 09-21-2008 08:36 PM
Cold start problem with 1986 300SL 86 SL R/C107 SL/SLC Class 12 07-17-2006 11:07 AM
Hard to start up - 300SL-24 Guest (MBNZ) R230 SL-Class 2 03-08-2002 11:06 AM
