Gas Light Flashing - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 03-26-2011, 04:22 PM Thread Starter
kylesl500's Avatar
Date registered: Mar 2011
Vehicle: 1999 Mercedes SL500 1987 BMW M5 2006 Jaguar XJR 2009 Ford Expedition
Gas Light Flashing
hey i was driving my sl500 adn all of a sudden the gas light starting flashing for no reason it had half of a tank and i didnt know what that means. i was wondering if aanyone had any ideas of what it was?
Thanks
Kyle
kylesl500 is offline
post #2 of 21 (permalink) Old 03-26-2011, 04:28 PM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 723 Post(s)
Fuel level sender #15 ?
RKH is offline
post #3 of 21 (permalink) Old 03-26-2011, 05:56 PM Thread Starter
kylesl500's Avatar
Attachment 365502
will it hurt to keep driving it you think
post #4 of 21 (permalink) Old 03-26-2011, 06:00 PM
RKH
RKH's Avatar
Quoted: 723 Post(s)
I shouldn't hurt anything, just don't run out of gas.
You should have some idea how many miles a full tank will take you and can just keep track of that.
RKH is offline
post #5 of 21 (permalink) Old 03-26-2011, 06:11 PM Thread Starter
kylesl500's Avatar
thats the wierd thig is the guage still works just every once in a while the light flashes and if iu turn car off and restart it its fine then
post #6 of 21 (permalink) Old 03-26-2011, 06:28 PM
Outstanding Contributor Always Remembered RIP
eric242340's Avatar
Quoted: 334 Post(s)
It flashes to tell you that there is a huge leak in the EVAP system, usual culprit is the gas cap loose or not tightened properly.
ERIC.
This definition tells you all you need to know about 'PC'
PC, aka, Political Correctness, is a doctrine, fostered by a delusional, illogical minority (Liberals/Socialists) and promoted by the mainstream media, which holds forth the proposition that it is possible to pick up faeces by the clean end.
eric242340 is offline
post #7 of 21 (permalink) Old 03-27-2011, 08:00 AM
SunGuy61's Avatar
Vehicle: 1987 560SL Gone but not forgotten! & 1999 SL500 For Now
Quoted: 6 Post(s)
Send a message via AIM to SunGuy61
....as well as the line going to the charcoal cannister behind the left front headlight. If loose/broken/cracked, same symptoms of the flashing fuel indicator lamp.
FATHERTIME likes this.
Bob Jones
Bradenton, FL
SunGuy61 is offline
post #8 of 21 (permalink) Old 03-27-2011, 09:08 AM
Date registered: Sep 2007
Vehicle: 1999 silver sl500
Gas cap!
I had the same problem once in the while,it would flash even with a half tank of fuel,turn it off and back on it goes away,So i kept thinking it was a loose gas cap,but it would come on another day,so the cheapest and simplest thing to do was buy a new gas cap and tether from mercedes abot 26 dollars,That was a few months ago,Light problem solved,might have been a leaky gas cap,the rubber must have gotten hard and the seal wasnt good! Goodluck! regards speedmaster2
speedmaster2 is offline
post #9 of 21 (permalink) Old 03-27-2011, 01:39 PM
Date registered: Sep 2008
Air leak somewhere
You have a air leak some place you will eventually get a Check engine light. Check all your vacuum lines, i had the same problem when i bought my car. it was an unhooked vacuum line. do a few seaches on here and you will see the most common spots. Checl all lines to and from the purge valve.
BAHRAINI AMG likes this.
blahop is offline
post #10 of 21 (permalink) Old 03-27-2011, 06:07 PM
RM98SL's Avatar
Vehicle: 98 SL500
Quoted: 9 Post(s)
My gas gauge was blinking and then after driving for awhile the check engine light came on.
Changed the gas cap it still happened and then changed the purg valve - problem solved.
Hope it helps.
RM98SL is offline
Flashing gas light blinks then disappears Episode7 R170 SLK-Class 2 11-23-2009 12:57 PM
Check engine light and flashing Low gas light benz3000 W210 E-Class 4 08-04-2009 01:17 PM
Low Gas light flashing T0nyT0ny W202 C-Class 2 06-28-2008 03:50 PM
Gas light flashing with gas tank full qha000 W140 S-Class 1 03-29-2007 08:52 PM
Flashing orange light on gas gauge snojet R129 SL-Class 6 10-05-2005 12:49 AM
