1993-1995 Engine wiring harness problems - Mercedes-Benz Forum
post #1 of 108 (permalink) Old 12-06-2004, 07:46 PM Thread Starter
bcool's Avatar
Date registered: Jan 2004
Vehicle: 93 white sl500
Does anyone know were i get a wiring harness for my 93 sl[?]. Any info would be a great help.
thanks
byron
bcool is offline
post #2 of 108 (permalink) Old 01-11-2005, 02:15 AM
Date registered: Dec 2004
RE: 119 engine wiring harness
what is wrong with your loom? i today had problem with 119 engine loom, all gone brittle and fell apart[:)]
benzforever is offline
post #3 of 108 (permalink) Old 01-12-2005, 02:02 AM Thread Starter
bcool's Avatar
It was dry and crumbing and was making my car run rough. I had it replaced last week and my runs like new.
Bcool[:)]
bcool is offline
post #4 of 108 (permalink) Old 01-12-2005, 06:29 AM
josephanthony's Avatar
Vehicle: 2009 SL550 Silver Arrow Launch Edition, 2013 Mercedes Benz C300 4Matic
Quoted: 5 Post(s)
Send a message via AIM to josephanthony
1995 M120 engine wiring harness
I've been following your plight...My 1995 SL600 is in the "OPERATING ROOM" today, after waiting for part for several weeks. I asked the tech to save the harness so that I might get some pictures to share with the group, but said since they partially covered it under warranty, it needed to be returned to Mercedes Benz. I am going to try to get some PICS anyway, before they send it out.
"Quiet Storm"
When you change the way you look at things,
the things you look at change.
josephanthony is offline
post #5 of 108 (permalink) Old 01-18-2005, 02:55 AM
Quoted: 5 Post(s)
RE: 119 engine wiring harness End Result
Harness replaced. I got my car back yesterday. Other than having to re-set some of the electronics, infra red entry sync., radio, seats, etc., all minor, my car has never run smoother! I have more horses than ever experienced since I bought the car in August. The dealer had to replace the mass air sensor on one side along with everything else. I looked at the harness before they sent it back to Mercedes. It was a mess! Insulation crumbling off of interior wiring throughout, not just in the high temp. areas. Glad I got it done. I'm glad they covered most of the job also, as the part alone was over $2,000. I'm Back!
"Quiet Storm"
post #6 of 108 (permalink) Old 02-12-2005, 10:06 PM
Date registered: Feb 2005
Vehicle: 97 500SL
Defective wiring harness identification?
Is it possible to identify a potentially defective wiring harness on a '94 500SL that I am looking at buying? Where, exactly, are the wires/harnesses located underhood?
(I'm refering to the numerous posts on this topic)
The car has 77K miles and otherwise appears flawless.
Thanks!
davyjo is offline
post #7 of 108 (permalink) Old 02-14-2005, 01:34 PM
Vehicle: '03 SL500, '03 SL55, '97 SL320, (2) '91 300SL, (2) '91 500SL, '00 S500 -- all for sale
Quoted: 568 Post(s)
RE: Defective wiring harness identification?
The wiring harness is defective on all '94s! In most instances you have to cut into the outer covering to see it (picture). If you like the car you are looking at, I would not let the wiring issue stop you. Just be aware that it will probably have to be replaced at some point in the car's life.
By the way, it is best not to disturb the wiring under the hood if you have an original harness. Because while much of the insulation has deteriorated, wires are not yet shorting together and only do so when they are moved around.
bobterry99 is offline
post #8 of 108 (permalink) Old 02-14-2005, 02:02 PM
Date registered: Sep 2004
Vehicle: 2006 Silver CLK350 Cabriolet
Send a message via Yahoo to sfguy100
Bob,
Thanks for the input on the 94 SL500 harness. Are there other years and/or models (ie: SL320,SL500 & SL600)to be advised on? What year was this finally corrected? Thanks, Gary 97 SL500.
sfguy100 is offline
post #9 of 108 (permalink) Old 02-15-2005, 04:15 AM
Quoted: 568 Post(s)
All Mercedes models produced during model-years 1993, 1994, and 1995 have faulty wiring harness insulation. Exception: 1993 six-cylinder models with KE fuel injection (300SL among these).
There are four harnesses to be concerned about: (1)the engine harness on the engine, (2)the engine harness on the body, (3)the starter/alternator harness, and (4)throttle motor assembly harness.
In some cases dealers have replaced these gratis out of good will. This is most likely to happen with a lower mileage car.
UPDATE: in July '09 a Mercedes tech told me that he is hearing of insulation failures of interior wiring as well.
post #10 of 108 (permalink) Old 02-15-2005, 07:49 AM
dsilvar's Avatar
Vehicle: 1989 560SEL, 1994 SL 500
thanks Bob.
dsilvar is offline
1993-1995 R129 SL Engine Wiring Harness Problems bcool R129 SL-Class 342 12-15-2018 12:30 PM
1995 SL500 Engine Wiring Harness Replacement Keepontrucking R129 SL-Class 9 04-26-2018 07:51 PM
Engine Wiring Harness for 1995 C280 C280Marvin General Mercedes-Benz 1 01-10-2010 09:03 PM
need engine wiring harness 1995 c220 Joeyc220 W202 C-Class 0 06-27-2004 03:36 PM
