SL600 wiring harness repair (cracking insulation) - Page 25 - Mercedes-Benz Forum
post #241 of 254 (permalink) Old 06-14-2017, 03:02 PM Thread Starter
GUSMB's Avatar
Date registered: Nov 2005
Vehicle: MB CLS550 -09, MB SL600 -94, MB 560SL, MB 170s, Austin Healey Sprite
Quoted: 15 Post(s)
Originally Posted by jobar View Post
Hello everybody:
I own a SL600'93. The car was running with low power issues that pointed the cabling could be the problem. Found both ETAs bad. Rewired right one, no problems. But after rewiring left one, it starts rough, ASR light goes on, and rpm does not work. Checked all the wiring in the ETA, but I can't find anything wrong. I am pretty sure it runs in all 12 cyl, but didn't keep it idling for long.
Thanks..
There is a diagram that I made some years ago here, you can at least check to see if we have the same mapping:
MB SL600 7,2 Všth
Opinions are like assholes. Everybody has one...
GUSMB is offline
post #242 of 254 (permalink) Old 06-15-2017, 02:13 PM
Date registered: Mar 2014
Vehicle: R129 SL600, Year 93
Quoted: 7 Post(s)
I followed your webpage. Good guide. Thanks.
By the way, it is fixed. Welding issue, combined with one connector on ignition module loose (probably my fault)
So it is running again and waiting for the MAF cabling. But instead of cut and weld, I would like to run a paralel cabling and attach to the ECU connector.
Does anybody know where the MAF cabling ends, or what terminals?
Also a pinout would be very useful.
Thanks again
jobar is offline
post #243 of 254 (permalink) Old 07-03-2017, 03:53 AM
Quoted: 7 Post(s)
Thanks again
Found the ECU pinout while chasing another info. That's life.
MAF cabling done.
Just in case somebody needs it.
Pin 1 (Brown) Ground.
Pin 2 (Yellow/Red) Pin 34 ECU.
Pin 3 (Yellow/Violet) Pin 37 ECU.
Pin 4 (Yellow/Blue) Pin 23 ECU.
Pin 5 (Yellow/Black) Pin 17 ECU.
By the way, just drilled 2 holes in the ECU box to pass through the wires with a rubber grommet.
jobar is offline
post #244 of 254 (permalink) Old 03-22-2019, 09:11 AM
Date registered: Feb 2015
Vehicle: 78 300CD 79 300TD 84 300SD 84 300SD#2 88 300SEL 91 560SEC 84 560SEC 95 SL600 99 E300td 99 ML320
Quoted: 11 Post(s)
I am thinking I am going to have to do a rewiring on my 95 SL600 as it is running weirdly. Trying to see pics on p24 of this thread and there are broken placeholders for the pics. Any thoughts?
RichDiesel is offline
post #245 of 254 (permalink) Old 03-22-2019, 11:18 AM
kubasz's Avatar
Date registered: May 2009
Vehicle: 600SEL '93, SL600 '95, E55 '04
Quoted: 9 Post(s)
Hi guys
im a W140 forum user but as i recently got myself a R129 i started looking around here to see for common problems with that specific model and it seems there are similar problems on both models. I love M120 i repair wiring harnesses for these motors. I can imagine that sending parts to Europe may not be reasonable but maybe there are euro viewers here looking for help with this specific issue
kubasz is offline
post #246 of 254 (permalink) Old 03-22-2019, 11:59 AM
Date registered: Nov 2002
Vehicle: '82 500sec euro, '95 Ford F150
Quoted: 148 Post(s)
https://www.benzworld.org/forums/att...af-harness.pdf
The MAF harness is available new from the dealer. Lists 140-ish. Fits both w140, and r129 V12s.
I always run the wires in this heatshield to prevent future deterioration of the wire insulation.
ID:	2498254   Click image for larger version
ID:	2498256   Click image for larger version
MAVA likes this.
roadhouse is online now
post #247 of 254 (permalink) Old 03-22-2019, 06:55 PM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1232 Post(s)
Thank you Thank you for the update!!!
I thought this harness was no longer available....
The Mercedes Dealer out of Florida has the harness for $100
https://www.mercedespartshub.com/oem...ket-1405400081
FYI, Parts hub is the cheapest for actual MB parts anywhere. They beat my two dealers that sell to me at Whole-Sale-Prices. MB Parts Hub is 15% to 20% cheaper than any my past sources.
Rich,
Sorry some of us have our benzworld portal to display the max pages per computer screen, so it was not Post 24, so what post is it?...
I had posted this a while, and it may help on post 12
https://www.benzworld.org/forums/r12...l600-95-a.html
Inspect your wires, and open those wiring plastic channels.
All the best,
Martin
MAVA is offline
post #248 of 254 (permalink) Old 03-22-2019, 08:37 PM
Photodude's Avatar
Date registered: Apr 2013
Vehicle: 2004 E320, 2000 SL500
Quoted: 162 Post(s)
Martin,
I found this website the other day. Prices are the same as MB Pats Hub as far as I can tell. When I scrolled down to contact info, location and phone number are the same as Encino Dealer. They offer at the check out option of local pickup with no shipping charges. Could be very convenient
I ordered MAF from them $190, got the e-mail the same day part NLA. They promptly updated their part catalog with that info.
https://www.mercedespartsdepot.com/
MAVA likes this.
Andrew
Photodude is offline
post #249 of 254 (permalink) Old 03-23-2019, 10:41 AM
Date registered: Apr 2012
Vehicle: 1995 S600
Do I need the package one or two times for both MAFs?
kerrman is online now
post #250 of 254 (permalink) Old 03-23-2019, 12:15 PM
Quoted: 148 Post(s)
One harness per package
kerrman likes this.
Lower wiring harness & crackling wire insulation batmanandbobbin W124 E,CE,D,TD Class 11 05-06-2018 02:14 PM
SL600 MAF Sensor Harness Plug Repair mohdnoor R129 SL-Class 5 07-24-2013 02:48 AM
95 SL600 wiring harness dabenz99 R129 SL-Class 15 01-13-2012 04:35 AM
1994 SL600 problems. wiring harness and throttle body 190e2.3euro R129 SL-Class 0 04-06-2010 03:49 PM
Wiring Harness Insulation Disingegrating on E320 [email protected] General Mercedes-Benz 5 07-08-2006 09:54 AM
