SL600 wiring harness repair (cracking insulation) - Page 23 - Mercedes-Benz Forum
post #221 of 254 (permalink) Old 04-24-2014, 10:54 AM
Date registered: Apr 2013
Vehicle: 95 SL600 92 SC400 98 4runner 71 gto convertible
Quoted: 7 Post(s)
Hey Tracy,
Just a couple of quick things, it has been a while, but thank you for all the advice when I was having my LHM trouble. Found out the slave side motor went bad on the ETA, and Victor did a great job with a rebuild, nothing like having the beast back and running so well again.
Second, the $529 you were quoted, was that the complete job including the new wires, I mean I love getting dirty with repairs on the SL600, but 11 hours worth of mostly frustration would be worth a second thought of having either MB or my indy do that harness. All of mine have been replaced except the starter/alternator harness as well.
Michael
ops1-1 is offline
post #222 of 254 (permalink) Old 04-24-2014, 11:15 AM
tdoriot's Avatar
Date registered: Jul 2011
Vehicle: 1993 600SL, 1973 450 SL,1982 380SL,1998 SLK 230, 1968 Firebird, 2001 Dodge Ram 4x4,2005 Ford Escape
Quoted: 416 Post(s)
Post
Glad you are up and running ! The starter harness on the MBI motors estimate was $ 349.33. Seems to me you can get them for a couple of hundred. The labor was $ 180.00. If you have something gainful you can do to earn the $ 500, best left to a tech. It really is a bitch of a job. I don't know that I'd do it again. I think I'd bite the bullet.
tdoriot is offline
post #223 of 254 (permalink) Old 04-25-2014, 06:49 AM
WarrenC's Avatar
Date registered: Jun 2010
Vehicle: 1998 SL500, 1973 Avanti II, 2008 Silverado LTZ
Quoted: 43 Post(s)
Good thing you don't have anything gainful to do!
WarrenC is offline
post #224 of 254 (permalink) Old 04-27-2014, 07:01 AM
Date registered: Feb 2014
Vehicle: 1994 sl 600
I recently did my starter , alternator harness is it was a little difficult to get to around the starter but the rest of it was right there and easy to see and remove. Replace all 4'wires using the original connectors and put it back in . Now that I have done it I would be able to do it again on about three hours including the harness rebuilt. Total cost of wiring was very little. I took the money I saved and bought a new top for $395 and installed it too. Now that was a sticky job !
tdoriot likes this.
Mtnandy is offline
post #225 of 254 (permalink) Old 04-29-2014, 09:27 PM
tdoriot's Avatar
Quoted: 416 Post(s)
Post
Son of a Bitch ! Finally got the air injection hoses in today. That's been 2 weeks. I think they flew it in from Der Fatherland. Also replaced the engine oli dipstick that had a broken handle. The biggest 911 bitch was those goofy spring clamps that are up in the depths of the alternator bay. There is just about no way to compress that spring with pliers and work the hose on. Then in a fit of desperation tempered with sheer brilliance, I compressed the clamps in the vice, and put a small zip tie on all of them. After the hoses were worked on, I put a long screwdriver in the space between the tabs, gave it a twist which snapped the zip ties and the clamps snapped closed. Problem solved!
The rest of the job was putting the coolant bottle system (both bottles). And replacing clips, air boxes and ducting, clamps clips, battery cables etc. I stopped short of reinstalling the headlights pending a possible xenon transplant.
After the pre-requisite drum roll I twisted the key. Started immediately, oil pressure pegged, no low oil light, and alternator happy! Success ! That was a huge amount of bullshit resulting from some prick at the wire manufacturer using a cheap formula on the wiring insulation
GUSMB, WarrenC and Fritha78 like this.
tdoriot is offline
post #226 of 254 (permalink) Old 06-02-2015, 05:41 PM
Date registered: Aug 2007
Vehicle: 1994 SL600
Quoted: 2 Post(s)
I Need Help With my '94 SL600 Ignition Harness
Hello, if there is anyone out there who might be able to direct me to the color codes of the various injectors and senders on this harness, I'd be very grateful. I'm a good way through the rebuild and want to quality assure my wiring isn't totally screwed up before bundling it all up. The different colors have faded on some and what I did tape with others has left me with around 7 wires that are orphans at the moment...Have got way too much time into this to abandon it and I'm not in a position to spend the $1k that it costs to replace. Need to confirm the color/striping on the 12 injectors and the left cooling fan sensor and the left side ETA along with the temp sensor. Boy, these are some pretty rotten wires in this car..surprised it ran as long as it did.. Any help please...?
Medhawk61 is offline
post #227 of 254 (permalink) Old 06-03-2015, 03:08 AM Thread Starter
GUSMB's Avatar
Date registered: Nov 2005
Vehicle: MB CLS550 -09, MB SL600 -94, MB 560SL, MB 170s, Austin Healey Sprite
Quoted: 20 Post(s)
GUSMB is online now
post #228 of 254 (permalink) Old 06-03-2015, 06:05 AM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1255 Post(s)
Mr. 61,
Here are the schematics, but you need a windows machine running internet explorer.
NEXEDGE StarFinder
Martin
MAVA is offline
post #229 of 254 (permalink) Old 06-03-2015, 09:25 AM
Vehicle: 1994 SL600
Quoted: 2 Post(s)
Thanks!!
Very good of you to help me sir... Thanks so much
post #230 of 254 (permalink) Old 06-03-2015, 09:26 AM
Vehicle: 1994 SL600
Quoted: 2 Post(s)
Thanks so much...was pretty much done untill i could line these wires up properly..what a mess... shame on MB..
Lower wiring harness & crackling wire insulation batmanandbobbin W124 E,CE,D,TD Class 11 05-06-2018 02:14 PM
SL600 MAF Sensor Harness Plug Repair mohdnoor R129 SL-Class 5 07-24-2013 02:48 AM
95 SL600 wiring harness dabenz99 R129 SL-Class 15 01-13-2012 04:35 AM
1994 SL600 problems. wiring harness and throttle body 190e2.3euro R129 SL-Class 0 04-06-2010 03:49 PM
Wiring Harness Insulation Disingegrating on E320 [email protected] General Mercedes-Benz 5 07-08-2006 09:54 AM
