SL600 wiring harness repair (cracking insulation) - Page 15 - Mercedes-Benz Forum
post #141 of 254 (permalink) Old 01-18-2013, 02:12 AM Thread Starter
GUSMB's Avatar
Date registered: Nov 2005
Vehicle: MB CLS550 -09, MB SL600 -94, MB 560SL, MB 170s, Austin Healey Sprite
Quoted: 20 Post(s)
When the housing is disassembled, just start replacing wires:
25 wires in place:
GUSMB is offline
post #142 of 254 (permalink) Old 01-21-2013, 01:46 PM Thread Starter
GUSMB's Avatar
Quoted: 20 Post(s)
Time to start in the other end of the Engine harness:
GUSMB is offline
post #143 of 254 (permalink) Old 01-22-2013, 06:38 AM Thread Starter
GUSMB's Avatar
Quoted: 20 Post(s)
Gotten to the front connectors of the engine harness:
And the result of the two worst ones:
As usual more can be seen here:
MB SL600 7,2 Všth
GUSMB is offline
post #144 of 254 (permalink) Old 01-23-2013, 08:37 AM Thread Starter
GUSMB's Avatar
Quoted: 20 Post(s)
Before it used to pop up questions from time to time, either this information works and no more questions or simply it is not interesting...
I hope it is the first option
GUSMB is offline
post #145 of 254 (permalink) Old 01-23-2013, 11:10 AM
Fritha78's Avatar
Date registered: Aug 2011
Vehicle: 2012 E350 - 1994 SL600
Quoted: 64 Post(s)
I'm still following your progress. Don't give up on me.
Fritha78 is offline
post #146 of 254 (permalink) Old 01-24-2013, 10:17 AM
tdoriot's Avatar
Date registered: Jul 2011
Vehicle: 1993 600SL, 1973 450 SL,1982 380SL,1998 SLK 230, 1968 Firebird, 2001 Dodge Ram 4x4,2005 Ford Escape
Quoted: 416 Post(s)
Post
Me too ! It's great that you were able to source all those color codes ! Since we couldn't see a wire color on the TA's, we just used white and I labeled mine with some electronic wire labels. Tragic that the connectors are not available. That would make the whole process alot easier. Great work on what you are doing. Thanks for taking the time to document the process. It makes our job a bit less formidable when the time comes ! And make no mistake my friends, it will come !
tdoriot is offline
post #147 of 254 (permalink) Old 01-24-2013, 11:29 AM Thread Starter
GUSMB's Avatar
Quoted: 20 Post(s)
Never been known as a quitter so don't worry, I am a stubborn slow working Swede...
GUSMB is offline
post #148 of 254 (permalink) Old 01-24-2013, 11:31 AM Thread Starter
GUSMB's Avatar
Quoted: 20 Post(s)
Time to Clean up the rest of the harness:
Common leads for some sensors and injectors:
Red car, red cable ties:
Will be fixed a little bit more when in the car:
As usual, more to se here:
MB SL600 7,2 Všth
Complete gallery for the car:
Album: MB SL600 Všth 7,2l
GUSMB is offline
post #149 of 254 (permalink) Old 01-25-2013, 12:01 AM Thread Starter
GUSMB's Avatar
Quoted: 20 Post(s)
Old VS "New":
GUSMB is offline
post #150 of 254 (permalink) Old 01-25-2013, 10:57 AM
tdoriot's Avatar
Quoted: 416 Post(s)
Post
You have to admit, its amazing that these cars run at all with wiring in that condition ! I guess its just fortunate that the insulation remains have kept the wires separated. It's like you guys told me when I was wasting time trying to get the ASR to go away. REWIRE THE CAR ! I am lucky I had good harnesses in all but the throttle actuators. Probably the easiest fix. If it hadn't been for that, I would never have gotten the bargain I got on the car. Good work there GUSMB ! See Doug, you should have rebuilt your injector harness !
tdoriot is offline
Lower wiring harness & crackling wire insulation batmanandbobbin W124 E,CE,D,TD Class 11 05-06-2018 02:14 PM
SL600 MAF Sensor Harness Plug Repair mohdnoor R129 SL-Class 5 07-24-2013 02:48 AM
95 SL600 wiring harness dabenz99 R129 SL-Class 15 01-13-2012 04:35 AM
1994 SL600 problems. wiring harness and throttle body 190e2.3euro R129 SL-Class 0 04-06-2010 03:49 PM
Wiring Harness Insulation Disingegrating on E320 [email protected] General Mercedes-Benz 5 07-08-2006 09:54 AM
