Bose door speakers - Page 4 - Mercedes-Benz Forum
post #31 of 55 (permalink) Old 01-31-2016, 07:14 AM
Chewa's Avatar
Date registered: Jun 2015
Vehicle: 2007 E class Estate 280CDI (S211) 2000 SL 280 V6 (R129)
Quoted: 48 Post(s)
Originally Posted by rorypff View Post
One needs to remove the whole door panel for the later models too - it's no big deal.
I'm sure I just needed to remove the grille on my 2000 to replace the large speaker (an Alpine) on mine.
John
plus je vois les hommes, plus j'admire les chiens
Chewa is offline
post #32 of 55 (permalink) Old 02-02-2016, 02:26 PM
timonterey's Avatar
Date registered: Jan 2016
Vehicle: 1997 SL320 (114,500 mi.), 1997 SL500 (61,500 mi.)
Quoted: 4 Post(s)
Thanks to all for the info regarding door panel.
Also, confirming through Patty at 508-766-9522 that Bose is again using the 171800 part number for the larger Bose door speaker. -Tim
timonterey is offline
post #33 of 55 (permalink) Old 02-17-2016, 06:37 AM
terrypo's Avatar
Date registered: Mar 2014
Vehicle: 2012 E350 Cabriolet, 1997 SL600 Sport, Pano
Quoted: 30 Post(s)
Hi Tim
Did you replace your small speakers also? If so, were they part number 133619 as listed earlier in this thread? Did you replace the amp? My SL600 is a 97 as well so hoping to piggyback on your experience.
Thanks
Terry
terrypo is offline
post #34 of 55 (permalink) Old 02-17-2016, 04:31 PM
Date registered: May 2014
Vehicle: 1997 SL500 70K Miles
Quoted: 67 Post(s)
One thing that happens with these when they get wet is the cone deforms some and causes voice coil rub. That was the condition I found them in when I purchased by SL500 two years ago. I purchased the proper foam surrounds from eBay and re-foamed them both, while re-centering the coil. I also painted two or three coats of mod podge onto the outer surface of the cone (I suspect the water comes down the front of the driver and accumulates on the foam edge lip where it meets the cone). This I did to provide some protection from future water intrusion, though the car is now kept in the garage, so it should never wet again. One of the repairs--the more badly deformed cone--did not take and the distinctive crackle of voice coil rub returned rather quickly. I tossed that one and bought another used one which I also coated and the two have been in the vehicle for two years now and have worked fine since.
smata67 is offline
post #35 of 55 (permalink) Old 02-17-2016, 04:34 PM
timonterey's Avatar
Quoted: 4 Post(s)
Originally Posted by terrypo View Post
Hi Tim
Thanks
Terry
I did not replace the small speakers, nor the amp. The original problem was that the main door speakers sounded distorted, which was worse at low volume. Also, the screen on the old head unit was black, so the first thing we did was to replace the head unit.
We were delighted to find that with the Blaupunkt 420BT in place, the door speakers (etc.) sound great, so we have not even bothered, yet, to install the new (large) door speakers.
More regarding the antenna, later.
post #36 of 55 (permalink) Old 02-18-2016, 04:24 AM
isthenew's Avatar
Date registered: Jan 2014
Vehicle: 1989 300SE 232k miles
Quoted: 218 Post(s)
Hi Tim
Thanks
Terry
If you're looking for instructions on removing the rear amp, download TopHydraulics' instructions for removing the soft top left main piston. They're great for removing the interior trim (ignore the piston parts). And it'll say something like, remove the rear amp if necessary. So at that point, pull the amp. It's a few self-evident bolts. Oh, and the units are glued in or some such. I had to use a crowbar on mine the first time I removed it.
http://www.tophydraulicsinc.com/R129...%20Removal.pdf
isthenew is offline
post #37 of 55 (permalink) Old 02-18-2016, 02:09 PM
timonterey's Avatar
Quoted: 4 Post(s)
Originally Posted by smata67 View Post
... I purchased the proper foam surrounds from eBay and re-foamed them both, while re-centering the coil. I also painted two or three coats of mod podge onto the outer surface of the cone (I suspect the water comes down the front of the driver and accumulates on the foam edge lip where it meets the cone). This I did to provide some protection from future water intrusion, though the car is now kept in the garage, so it should never wet again...
What was your criteria for searching or finding the proper foam surround? How did you know you had the proper one?
Also, wouldn't coating a speaker cone with Mod Podge would alter the tonal response characteristics of the speaker? And even then, there may be (e.g., acrylic ) products that provide better water protection. E.g., I read on the Amazon Q&A that "If saturated with water Mod Podge will turn cloudy and peel off." http://www.amazon.com/Podge-CS11302-Original-16-Ounce-Finish/dp/B001IKES5O
Thanks
Tim
post #38 of 55 (permalink) Old 02-18-2016, 06:31 PM
Quoted: 67 Post(s)
The surround is a standard 6" cloth surround with an angled lip, you can confirm that it will fit measuring the cone diameter and comparing to the "inside roll diameter." I got mine from speakerguy2002 on eBay, link below. The mod podge is what I had on hand, there are probably better ways to moisture protect the cone.
Pair 6" Cloth Surrounds for Speaker Repair | eBay
Dimensions:
Inside Diameter - 4 5/16"
Inside Roll Diameter - 4 3/4"
Outside Roll Diameter - 5 5/8"
Overall Diapmeter - 6 1/4"
Angle Attach
There is an exterior grade mod podge which is reported to work well and be water resistant, but not waterproof. You can also use "outdoor acrylic sealer," folk art makes a product for outdoor crafting.
smata67 is offline
post #39 of 55 (permalink) Old 02-21-2016, 05:43 PM
timonterey's Avatar
Quoted: 4 Post(s)
Dimensions:
Angle Attach
Good info, thanks!
post #40 of 55 (permalink) Old 03-08-2016, 08:14 AM
terrypo's Avatar
Quoted: 30 Post(s)
Just spoke to Patty and ordered my speakers.
2 X part 171800 @ $60 each (larger door speaker)
2 X part 133620 @ $40 each (door tweeter)
508-766-9522 to reach Patty
terrypo is offline
WTB Bose door speakers jserio R129 SL-Class 23 08-25-2015 10:23 AM
FS: 98 99 MERCEDES ML320 ML350 LH RH DOOR SPEAKERS BOSE NEW cltcam W163 M-Class 2 11-19-2008 08:10 AM
FS: 98 99 MERCEDES ML320 ML350 LH RH DOOR SPEAKERS BOSE NEW cltcam For Sale/Wanted/Trade/Giveaway 0 11-06-2007 01:25 PM
Bose part #s for W129 lower door speakers askay Audio & Telematics Forum 0 11-01-2007 05:58 PM
Bose logo fell off one of my door speakers fdillard W163 M-Class 1 06-16-2003 04:24 PM
