Bose door speakers - Page 3 - Mercedes-Benz Forum
post #21 of 55 (permalink) Old 09-29-2015, 10:05 PM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1233 Post(s)
Originally Posted by RobbieV845 View Post
Does anyone know how the door speakers (above) are attached to the plastic cage?
I won't be using a 1-2 ohm system anymore so I'd like to replace the Bose speakers with speakers of today and the cage looks like the best way to get them to stay in the door.
Thanx
Robbie,
Not so fast, you may either have the speakers Artic is describing, or the the ones with the plastic frame held with 10 or so torx screws.
I do know the 93 has the one the 10 torx screws, and the 95 and up has the ones with the screws like Artic has shown you, and for the 95 and up one can use the ones of 2000 to 2004 cars as I replaced my 95 original speakers from a 2003 W220 door speakers, but my 93 has speakers of some weird oddball size.
Maybe someone with a 94 can confirm what you have..
All the best,
Martin
ArcticDweller likes this.
MAVA is offline
post #22 of 55 (permalink) Old 09-30-2015, 05:44 AM
RobbieV845's Avatar
Date registered: Mar 2011
Vehicle: 1994 SL500 (wife's) I have too many cars to list.
Quoted: 8 Post(s)
Send a message via AIM to RobbieV845
Hey Martin,
Thank you for your reply and warning.
Yes, if anyone knows if the 94's are like the 93 or 95's please chime in. I know I'll have to drill the new speaker cages and trim here and there, it'll just be 10x's easier to use the frame then not.
I have another speaker question, I located a great resource to help me with my speaker ordering, but it says nothing about dash speakers. She's never had a working sound system in the car so I don't know if they're strictly for the car phone or if they're part of the stereo system, in either case are they 3.5" speakers? another two directional tweeters would be great.
Thanks again
Originally Posted by MAVA View Post
Robbie,
All the best,
Martin
MAVA likes this.
Robbie V
"Wife's - 1994 SL500 (R129.067)"
American Muscle Car Collector
(Buy - Sell 60' - 70's)
RobbieV845 is offline
post #23 of 55 (permalink) Old 09-30-2015, 11:06 AM
Date registered: Jun 2015
Vehicle: 1995 sl600
Quoted: 22 Post(s)
For what it's worth, I used a door speaker from a '91 in my '95 SL600. The speaker housings were completely different so I reused the one for my car. I needed to trim around the edges a bit and drill three of the four mounting holes, but the speaker did end up fitting in my frame. The speaker mounting hole locations were different from '91 to the '95 but the depth was fine.
Johnnyd$ is offline
post #24 of 55 (permalink) Old 10-03-2015, 06:11 AM
Date registered: Oct 2015
Vehicle: 2000 SL500, 2004 CL500
Speakers are now $60 a piece. The part number is back to the original number as they used a similar speaker model (133619) in the past few years. Patty is still the contact at 508-766-9522
PRL898 likes this.
MBHHI is offline
post #25 of 55 (permalink) Old 10-03-2015, 09:43 AM
RobbieV845's Avatar
Quoted: 8 Post(s)
Yeah thanks just trying to get some homework done before I park her in the garage and start ripping out 1994 sound and replace it with 2000 n' teen sound.
And that'll require me to replace all of the existing wires/speakers/subs/amp /head unit. Car will look mostly stock other than the head unit.
Robbie V
post #26 of 55 (permalink) Old 01-29-2016, 03:24 PM
timonterey's Avatar
Date registered: Jan 2016
Vehicle: 1997 SL320 (114,500 mi.), 1997 SL500 (61,500 mi.)
Quoted: 4 Post(s)
In Feb 2010, on post #8 on this thread, plink49 clarified that it is not necessary to remove the door panel to replace the main door speaker. So, when replacing only the main speaker, should one assume that it is not necessary to order extra push pins, as advised in an earlier entry?
Also, if you are going to replace both the tweeter and the main speaker, is it then required to remove the door panel?
Finally, if the door speakers sound raggedy, as if a cone has been damaged, is it usually the case that the tweeter goes out along with the main door speaker? Or, are they pretty independent?
Thanks in advance,
Tim
timonterey is offline
post #27 of 55 (permalink) Old 01-29-2016, 05:11 PM
pcm
pcm's Avatar
Date registered: Mar 2008
Vehicle: 1990 500SL
Quoted: 10 Post(s)
In the early models (1990 - 1993) for sure, you have to remove the entire door panel.
pcm is offline
post #28 of 55 (permalink) Old 01-29-2016, 05:20 PM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 324 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
All first gen panels need to come off, the removable grill was introduced in late 1995 or so...
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X166 GL CLass GL63 (///AMG)
Ducati 999 with Termignoni and CF
Former Mercs:
W164 GL class GL450 (sold) - R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (passed on) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #29 of 55 (permalink) Old 01-29-2016, 09:14 PM
Date registered: Mar 2007
Vehicle: 2000 SL320, 2001 CLK320
Quoted: 368 Post(s)
One needs to remove the whole door panel for the later models too - it's no big deal.
isthenew likes this.
rorypff is offline
post #30 of 55 (permalink) Old 01-30-2016, 06:03 PM
isthenew's Avatar
Date registered: Jan 2014
Vehicle: 1989 300SE 232k miles
Quoted: 219 Post(s)
Thanks in advance,
Tim
I replaced the door speakers in my '96 (with the newer panels) by replacing the entire panel. A couple months later I tried to replace only the large, lower speaker on my aunt's '97. Even knowing exactly where everything went, after 10 minutes I still couldn't access one of the mounts. Pulling the entire panel is the faster, easier way.
So for your '97, I'd order those extra push pins. Yes, you need to remove the entire panel to access the entire door speaker mount. The smaller speakers are viable in the 2 cars where I had to replace the larger, lower speakers. So I'd say they're independent as for wear.
isthenew is online now
WTB Bose door speakers jserio R129 SL-Class 23 08-25-2015 10:23 AM
FS: 98 99 MERCEDES ML320 ML350 LH RH DOOR SPEAKERS BOSE NEW cltcam W163 M-Class 2 11-19-2008 08:10 AM
FS: 98 99 MERCEDES ML320 ML350 LH RH DOOR SPEAKERS BOSE NEW cltcam For Sale/Wanted/Trade/Giveaway 0 11-06-2007 01:25 PM
Bose part #s for W129 lower door speakers askay Audio & Telematics Forum 0 11-01-2007 05:58 PM
Bose logo fell off one of my door speakers fdillard W163 M-Class 1 06-16-2003 04:24 PM
